Like Tree2Likes
Multi quote?
Old 10-19-2018, 11:47 AM
Roelof's Avatar
Default Multi quote?
With the old software the MQ was simple, select all quotes by the MQ button and use the last with quote to pen a new post edittor with all selected quotes.
Somehow this does not work and I can not see how toe make it work again.
Roelof is offline
Old 10-20-2018, 01:35 PM
1/8 IC Fan's Avatar
Trader Rating: 95 (100%+)
On the desktop site?
1/8 IC Fan is offline
Old 10-20-2018, 01:36 PM
1/8 IC Fan's Avatar
worked now. MQ changed to red status, then i hit quote on mine... no issues
Old 10-20-2018, 03:11 PM
Roelof's Avatar
I only see the last quote in the text edittor.
I am using Win7 and IE11
Roelof is offline
Old 10-20-2018, 05:28 PM
R/C Tech Elite Member
Trader Rating: 72 (100%+)
works fine on mobile
freaksofnature is offline
Old 10-21-2018, 02:50 AM
Roelof's Avatar
It looks Microsoft related.
Yesterday I started up my Win10 tablet (I only use when I go away for a few days) and did the test. I have the same issue in IE11 and Edge but with Google Chrome it seems to work.
So 2 different Windows based machines both with IE11 and one with Edge show all the same problem.
Roelof is offline
Old 10-22-2018, 10:37 AM
RETIRED -- DO NOT PM
Yeah, looks like it's not working on IE. I'll send a report to our tech team.
IBThomas is offline
Old 10-22-2018, 03:25 PM
test
IBThomas is offline
Old 10-22-2018, 03:26 PM
test
IBThomas is offline
Old 10-31-2018, 10:52 AM
So it looks like the issue was that you may have been multi-quoting incorrectly. After you select which posts you'd like to quote, do not quote the final post, use the reply function instead. It should save all the posts you have quoted.
IBThomas is offline
Old 10-31-2018, 12:20 PM
Roelof's Avatar
Sadly that does not work either. If I do a MQ of 3 postst and click the "post reply" button no quotes are done.
Indeed in Chrome that works as also the way I mentioned first by clicking the quote button from the last MQ selected message.
I do not know if it has something to do with it but under the quick reply window there is a check box "Quote message in reply" that I can not select.
Roelof is offline
Old 11-01-2018, 09:22 AM
I should have been more clear. Don't use the quick reply button, use the post reply button. I've circled in red where to find the right button.
IBThomas is offline
Old 11-01-2018, 10:16 AM
Roelof's Avatar
That I have done but did not work in IE and Edge, but all did work in Chrome
Roelof is offline
Old 11-06-2018, 10:13 AM
Ok, thanks. I've updated my report to tech with your information.
IBThomas is offline
Old 02-10-2019, 08:43 AM
Roelof's Avatar
Any progress?
Roelof is offline
