Liquid Mask
Old 07-14-2006, 10:33 PM
  #31
racenut's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Kcdzim
It's PVA. plain white glue, like elmers, is PVA. it's not made from cow hooves anymore.
Yes thats the one... works fine...and cheap too. although thick coat will give you better masking
racenut is offline
Old 07-23-2006, 06:30 PM
  #32
*Chrominator*'s Avatar
Trader Rating: 19 (100%+)
How can you tell if it's on thick enough ?
I tried the sponge brush and there's spots that are so thick, you can't really see threw it .
Is that how thick it needs to be all over, or should it be transparent?
I tried spraying it on with my air brush , I can spray it with out thinning it , but it gos on pretty thin , and it seems like it would take along time to spray the hole body like that. Help!
*Chrominator* is offline
Old 07-23-2006, 08:20 PM
  #33
easiest way is to use a 4cm wide brush that has plastic brisstles (thin brisstles) the cheap brushes you can get from hardware stores are good. natural bristles tend to soak up the glue, but the plastic bristled brushes work great and wash out the glue very easily.
if been using the same brush for about 10 bodies, and i have gotten used to the application method, 1 thickish coat is usually enough. i dip the brush in, make sure there is a god amount on the brush and spread it around so there is roughly a 1 to 1.5mm film left
if you can see the brush strokes very heavily/pronounced on the glue, it is probably due to the fact you brushed over it too hard and made a thin section.
either that or just do a second coat.
TomB is offline
Old 07-23-2006, 09:03 PM
  #34
racenut's Avatar
I use brush, apply the mask, let it dry and apply another coat again. I usually apply 3 to 4 coats.
racenut is offline
Old 07-24-2006, 01:54 AM
  #35
SHOP UFO's Avatar
Sorry for asking,
Do you have a picture what the package looks like?
Thank you.
SHOP UFO is offline
Old 07-26-2006, 02:00 PM
  #36
Kcdzim's Avatar
Originally Posted by SHOP UFO
Sorry for asking,
Thank you.
Kcdzim is offline
Old 07-30-2006, 12:14 AM
  #37
racenut's Avatar
racenut is offline
Old 08-24-2006, 03:13 PM
  #38
Default 16 oz or 32 oz
How many bodies can you do with the 16oz bottle of liquid mask?
Was debating about the 16 oz or 32 oz bottle.
Thanks.
bigdog xxx-s is offline
Old 09-01-2006, 06:24 AM
  #39
racenut's Avatar
Thanks.
3 bodies for 16 oz bottle, havnt tried 32 oz
racenut is offline
Old 09-01-2006, 06:25 AM
  #40
Get the 32oz bottle then when you get low, call the number on the bottle and order a gallon from Bob directly. It'll be a heck of a lot cheaper in the long run.
Tony
RcCzarOfOld is offline
Old 09-05-2006, 10:43 AM
  #41
gibbous's Avatar
Spraylat is $60 for a gallon from coast, shipping is a flat $7, so it seems pretty cost effective to me...until you compare it to a gallon of elmer's:
http://www.artstuff.net/white_glue.htm
20 bucks??? Wow, that's comparatively cheap.
Okay, so the MONEY question is, have any of you used BOTH Spraylat and Elmer's, and which one works better?
gibbous is offline
Old 09-05-2006, 12:30 PM
  #42
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
3 bodies with a 16 oz, wtf are you doing? I get like 20 bodies out of a pint of divleys.
L.Fairtrace is offline
Old 09-08-2006, 10:53 AM
  #43
Carbonator's Avatar
Hee Guys,
I just ordered Faskolor Fasmask. The shop that caries the liquid mask stuff near me only has Fasmask.
I have never tried it before, always used TESA maskingtape (is like 3M), but wanted to trie liquidmask.
Have you guys any specific tips for Fasmask? Thick coat; extra thick coat?
If I was to spray it on with my airbrush, with wat should I thin it?
Denatured alcohol or so?
Hope you can help.
RA
Carbonator is offline
Old 09-08-2006, 10:59 AM
  #44
dpalXRC's Avatar
you just brush it on like any other liquid mask. Three coats is all you need.
That stuff kinda smells like cheese. So use it outdoors. Other than the smell it works great.
dpalXRC is offline
Old 09-08-2006, 11:14 AM
  #45
You can just use windex to thin the mask for spraying. If you do go that route, you'll need more than 3 coats. Probably more like 6. And you need to clean your brush immediately when you're done as it will clog it up pretty bad.
Tony
