Help!!!!
Help!!!!
I just used my Iwata and when I was painting my body it was spitting out the paint like a web??? The paint was everywhere, like cobwebs....pretty much ended up looking pretty bad.....any idea what is causing this? It is getting pretty frustrating, I did try thinning the paint....same thing happened
there could be a clogg in it.
Registered User
Cob webbing is actually a technique too, so some day you might actually be trying to get the effect.
To make your gun cob web you usually spray thick paint at a very low pressure. So try increasing your air pressure. What do you usually shoot at? I'm fond of 20-30 psi myself. Anything lower and I usually have to thin the paint to water to make it spray how I like.
Clogs on the tip and in the gun can also result in webbing. Also extreme air pressure can sometimes cause webbing to occure with thick paint.
Originally Posted by BadSign
I used to get this same problem with pactra paints, until I began thinning them. What paint are you using?
What technique do you guys use to thin paint? What exactly do you you use? I going to order an assortment of Parma Faskolor, does this have to be thinned? Also, what do you do for quick color changes? I use a gravity feed.
Thanks.
Wes - What are you using to thin your paints? Thanks.
