Questions from a newbie painter
Hi all,
I just recently purchased an Iwata Neo CN. It works quite well with the faskolor paints I purchased. That being said, I want to start decanting some Tamiya paints and using them. However, I don't what I will need in order to clean my aibrush when I am done using the Tamiya PS paint. So I need to know the following:
What can I thin / clean up with on Tamiya decanted PS paint?
Are Tamiya PS paints that have been decanted, compatible with the water based Faskolor paints?
Are there any other gotcha's I should know about when using Tamiya PS paint in an aibrush?
Thanks for your help.
According to Tamyia, the sell a thinner X-20A. This will work for cleanup. I saw a discussion that said water would work for their PC paint also.
Tamiya paints are not compatible with water for clean-up. The paint gums quickly and is a pain to get off of or out of anything once introduced to water. I don't know how the PS paints react painting under or over dried Faskolor paints. (one is water based, one is solvent based, I would not mix them) I used the Parma thinner with Tamiya PS paints with no issue, it worked just like any paint thinner should work.
Definitely keep any thinner away for lexan. I did not have an issue with it turning gummy, but it did turn the lexan brittle to the point where it got cloudy and cracked. A finger could easily be pushed through the area with little force. It was as if the thinner sucked all the moisture right out of the plastic. Ruined a new body trying to remove some paint runs. Live an learn.
I ended up decanting some Tamiya PS paint and have concluded that it is some sort of Lacquer paint. I purchased some denatured alcohol to see if that would work to clean up the paint and it failed miserably. Then I used some lacquer thinner and it worked beautifully.
Tamiya (PS) Dark Blue...?
I sprayed a Tamiya Body with Tamiya PS - Dark Blue(item # 89925 - spray-can).
-it layed down dark blue
-after a few spray passes; the color ended-up looking like a Midnight Blue or Raisin.
-I back the so-called Dark Blue with Tamiya Black(PS 5).
I wanted a Dark Blue body; not dark raisin.
Anyone have info on the Tamiya PS - Dark Blue spray-can paint?
Thank You
Thank You
Thank You
Thank You
Thanks for the info nubs.
When I started spraying the Tamiya PS Dark Blue; -the color started-out as dark blue. -as I sprayed a few more coats the color started to change (to the current Midnight Blue color). -this is before I backed it with Tamiya PS 5.
I'm asking if anyone have used this paint before; but your info helps a lot.
Tamiya (PS)Dark Blue. . . . . . .Color Not Too Bad
I sprayed Tamiya (PS) Dark Blue and PS 5 - Black (also as a backing) on a Tamiya Body. I used Tamiya Masking Tape for the lines.
The paint-job came-out alright (my best yet).
Once the over-spray cover was removed; the color now looks more dark blue-ish.
I've checked out a few how to paint videos on YouTube.
-I learned a few paint pointers.
I thought the Tamiya (PS) Dark Blue would be the same as the Tamiya (PS-59) Metallic Dark Blue; without the metallic.
I was wrong.
It looks more like the color of Baked Blueberry Pie Filling.....?
