Duratrax paint 'fuzzy'?
Old 04-03-2016, 10:29 AM
whitrzac's Avatar
Trader Rating: 96 (100%+)
Default Duratrax paint 'fuzzy'?
I'm still learning with my airbrush(hp-cr).
Faskolor works fine. I can paint decently with it.
I tried the new duratrax airbrush paint and it came out all stringy and fuzzy. Almost like I was shooting silly string I tried more pressure, less pressure, thinner and thicker and it didn't change.
What am I doing wrong?
whitrzac is offline
Old 04-04-2016, 05:20 AM
snoopyrc's Avatar
Some of that stuff just does the spider web thing when you spray it. You might not be doing anything wrong. Pressure and humidity effect it also. You may just have to pause and wipe the web out. Don't do that while your paint is wet of course.
snoopyrc is offline
Old 04-04-2016, 05:44 PM
whitrzac's Avatar
Almost no paint was hitting the body, It was all strings.
whitrzac is offline
Old 04-04-2016, 07:49 PM
Colors_By_Dave's Avatar
Trader Rating: 84 (100%+)
Thin it down until it stops. Pactra was known for needing a lot of reducer.
Colors_By_Dave is offline
Old 05-08-2016, 08:21 AM
I had the same problem when not thinned enough. I thin 50/50 and it usually solves the problem.
RookieRacer00 is offline
Old 05-10-2016, 06:44 AM
Apco1's Avatar
I always have to thin the pactra paints about 100%, same amount of paint to thinner. I still prefer them to the acrylics personally.
Apco1 is offline
