View Poll Results: What is your Favorite Airbrush?
Iwata
59.97%
Paashe
16.91%
Badger
14.27%
Other
10.85%
Multiple Choice Poll. Voters: 1254. You may not vote on this poll
Like Tree2Likes
YOUR FAVORITE AIRBRUSH
Old 09-10-2010, 08:31 AM
  #211
bllski's Avatar
http://www.amazon.com/Iwata-Eclipse-...4128502&sr=8-1
I was looking at this is the included compressor good enough and is this the iwata I see everyone talking about on here 235 for brush and compressor
bllski is offline
Old 09-10-2010, 10:26 AM
  #212
Rugspin's Avatar
great airbrush.....I have one but if your going to paint with the acrylic paints, ie. Faskolor, Createx, AutoAir you should look at the revolution CR it has a larger needle which works better with the thicker paints. You can still get all the thin line detail you would ever want just passes the paint better.
Rugspin is offline
Old 09-10-2010, 11:11 AM
  #213
bllski's Avatar
Thanks it would be mostly for lexan bodies, do you think that air compressor can handle the job or should I skip the combo and get a better compressor? This is just to paint bodies and have something to screw around with.
bllski is offline
Old 09-10-2010, 02:11 PM
  #214
chris moore's Avatar
Trader Rating: 96 (99%+)
That compressor will work but tankless compressors like that one can give a slight pulse through the line. That combo is mostly designed for the nail tech industry.
chris moore is offline
Old 09-10-2010, 04:43 PM
  #215
Rugspin's Avatar
I personally just use a good old regular 5 gallon air compressor. Very consistant fills up maybe 1once every few hours depending on how much im spraying.... Also the smaller compressors cant really deliver the PSI you might want to use. I vary anything from 15psi to 60psi.. average is 40 to 55
Rugspin is offline
Old 09-10-2010, 08:33 PM
  #216
bllski's Avatar
I have a 5 gallon chraftsman air compressor would I just need a dryer and a better regulator, what would I need as far as hose adapters. that would save me a ton of money using my garage compressor.
bllski is offline
Old 09-11-2010, 03:00 AM
  #217
+1 on the iwata hp-cr. I just got mine yesterday and it is so much easier to use than my other airbrush which has a .35 tip. I don't have to thin paints as much and I can still get some very fine lines. I just get a lot better consistency and more control.
I think the other brush won't leave the shelf as much now.
BenV.2 is offline
Old 10-10-2010, 03:20 PM
  #218
aeronb's Avatar
I just voted for the Iwata but it's the only one I've ever used. Bought it based on what I read here. I've been very happy with it so far.
I use my shop air compressor so, I have plenty of air there.
aeronb is offline
Old 10-16-2010, 08:34 PM
  #219
DOUGHBOY's Avatar
Talking
I HOPE THIS IS NOT A STUPID QUESTION BUT CAN YOU USE CREATEX PAINT ON RC BODIES??
DOUGHBOY is offline
Old 10-16-2010, 08:48 PM
  #220
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
yes
20 SMOKE is offline
Old 10-16-2010, 09:18 PM
  #221
DOUGHBOY's Avatar
I WISH I WOULD HAVE KNOWN THAT SOONER.. I BOUGHT A COUPLE OF BOTTLES OF THAT STUFF WHEN I BOUGHT MY FIRST AIR BRUSH JUST TO PRACTICE WITH.. THEY HAVE WAY BETTER COLORS THAN THE CRAPPY PACTRA STUFF I HAVE ALWAYS USED.. I AM GOING TO MICHAELS TOMORROW TO STOCK UP MY PAINT SUPPLIES
DOUGHBOY is offline
Old 10-21-2010, 07:38 AM
  #222
Default Paasche Talon
I love this brush. I also own an Iwata HP-C, but I use my Talon the most.
tjcerva is offline
Old 11-06-2010, 07:18 PM
  #223
BigRon's Avatar
Trader Rating: 22 (100%+)
Do you guys prefer the gravity feed over the bottle feed. If so, why?
BigRon is online now
Old 11-07-2010, 01:54 AM
  #224
For Rc shells I prefer gravity feed because it's easier to get into tight spaces without a bottle hanging off the bottom of your brush. I've never used a bottom-feed airbrush though.
For general artwork (canvas, tshirts) a bottle fed might be better because it can hold more paint.
BenV.2 is offline
Old 12-17-2010, 12:19 PM
  #225
Originally Posted by superslow
yeah the iwatas are definately the best, the hp-cs about 110.00 from coastairbrush.com they are an direct iwata dealer.
also a tip i once received from crosseyed one of the best airbrushers in the world from canada, was to add a little 409 to the water based paint as it actually melts the paint and makes color transistions super smooth
www.coastairbrush.com
Can I please ask what 409 is?
jeremy mac is offline
