OEM BMW Paint on Lexan
Old 01-18-2015, 03:00 PM
blf
Default OEM BMW Paint on Lexan
I'm assuming all my poly paints stick for a reason, but has anyone ever used OEM automotive paint on the inside of a Lexan body with any success?
I can buy the paint in a spray can from a vendor I use for the real parts
Thanks for any input
blf is offline
Old 01-18-2015, 03:48 PM
carbongoat's Avatar
Only way you can use it would be to scuff body and put flex agent into it.if not it will just flake right off.
carbongoat is offline
Old 01-18-2015, 05:29 PM
blf
Ok ----- what are some manufacturers who make a dark blue metallic flake lexan paint (spray can)?
blf is offline
Old 01-18-2015, 07:38 PM
carbongoat's Avatar
Duratrax is prob gonna be only one with a blue metallic.not sure if lrp does or not.if you were going to airbrush you could mix it with duratrax, lrp, spaz stix.
Old 01-25-2015, 08:20 PM
Trader Rating: 5 (78%+)
you can spray it without scuffing or adhesion promoter, just spray it and lay down a coat of sealer. I actually have some ppg white that was left over from a bmw m3.
Smithracer11 is offline
Old 01-26-2015, 05:12 AM
blf
Wow ---- thanks for the tip ---- I may just go with Tamiya PS-59 (Dark Blue Metallic) - have some of that on the way BUT would love to try this out with sealer ----- what type/brand sealer? I use dull and gloss coat spray for my static models, so, same thing here or is there a specific, flexible, sealer I need?
Thanks again
blf is offline
Old 01-28-2015, 05:59 PM
See of tamiya makes a clear coat or use black or white, but using those might change the tone of color.
Old 01-29-2015, 01:38 PM
Trader Rating: 18 (100%+)
non-polycarb paint has always flaked off for me. Let us know how it goes
2ZON is offline
