liquid mask help ĦĦĦ
Hi guys ..
i want to use the bob dively paint mask but i´m not an expert i have a few jobs with rattle can ..
It will be easy to use with the can, or i keep away and still with the tape..
any advice will be welcome...
The mask will be OK.
Apply 4 layers, letting it dry well between each layer of mask,
When spraying, spray many light coats and not heavy coats. Heavy application of paint will cause the paint to run/bleed under the mask.
