Poll for you painters: Radio painting pricing
A buddy of mine and I have a disagreement over how much a project should cost. Basically, it is to paint a used M11X radio, minus the buttons, dial, and trigger, leaving them the original color.
How much would you charge and what kind of paint would you use?
TIA...
TIA...
wow - I personally wouldn't take that job. So many things that could go wrong especially if I'm the one who has to take the radio apart and put it back together. I'd give him a few references to some nice vendors that do wraps and call it good.
But if I were to do it I would charge 1 hour labor for assembly and disassembly
Cleaning and prep of the plastic parts. Prep would include an coat of adhesion promoter followed by a basic primer and some wet sanding.
Paint would be my normal water based Auto Air color - one color for main body and one color for wheel housing (lots of color options)
Top coat would be a polyurethane clear coat (automotive grade)
cost would be on the order of what I would ask for doing a SC body
rice_man: Thanks for your feedback. Yes, the M11X, along with its M8, M11, and M12 kin, is a bit more complex that most other radios, I guess due to the multi-plane design. But I think the design also opens it up to more creative options. Oh, and what would you ask to do an SC body?
I'd only do it if it were pulled apart already. And if it were, I would do it for $100-$150 depending on the design wanted on it.
Its a lot of work. Especially if you have to take it apart. Are there any pieces that need to be masked? Also the paint is going to be more expensive. It has to at least be a $100. Its gets frustrating when people underestimate what it takes to put out a nice paint job. A lot dont realize the prep that goes into it.
At least $100, likely more.
