Airbrush help needed
Hi was looking to get a new airbrush anyone know if the Parma Faskolor F-1 Airbrush is the same as the iwata hp-cs it looks the same and uses the same assesories like the cleaning station that looks exactly like iwata's also?
If not how do the 2 compaire what's the differance on them both?
THANKS
THANKS
Suspended
FYI the Parma is not a badger It is a Iwata made for parma.(or a CLONE). all the parts and pieces will interchange.. Its way far away from a badger..
Dave do you own either of these I do..
badger is a syphon feed not a gravity feed like the brushes Reptile asked about..
I own a badger A1 and also own the Parma F1.. and I only but Iwata tips needles ..
O well to late ordered the eclipse! guess i could have saved a few $$ with the F-1
Have a few ?' if sombody can answer... I have a badger 150 will the hose i have work with the Iwata eclipse?
also you guy's ever use this Medea Super Lube to keep the airbrush lubed?
Well, I sure got told off. I want to thank you for opening my eyes.
I guess I will sell the five Iwata's I have owned for 7 years and rush out to buy a private labeled Parma F1, because you say so. And I am sure Badger only makes siphon models, right?
Well, maybe you should check out the Badger (Thayer-Chandler) website and study the model 5000.
http://badgerairbrush.com/Omni_Airbrushes.asp
Kinda looks like the Parma F1, strange.....nothing like any Iwata you find at the Iwata website.
http://parmapse.shptron.com/p/faskol...et?pp=15&pp=15
Parma F1
Badger TC 5000
But I'm sure I must be wrong. Because your right.
Parma F1
Badger TC 5000
Last edited by Colors_By_Dave; 02-06-2013 at 05:27 PM. Reason: Fixed the Parma link to the gravity model.
http://badgerairbrush.com/PDF/Old%20...nt%20Parts.pdf
More interesting history on the Thayer Chandler A series. Some really good data out there if one takes the time to research and read.
Well...uh.. Dave
As far as the air hose working with the Iwata you'll have to get another one or at least an adapter. The one that came with the Badger has a smaller fitting on the air brush end. You may also want to invest in a quick connector for the air brush end. It just makes life easier.
Here's where to find all the adapters, hoses, etc...
http://www.tcpglobal.com/airbrushdepot/abairhose.aspx
Air Brushes
Paul
Hi Guy's i ordered one of these to fit may badger hose and airbrush
http://www.ebay.com/itm/380573019212...84.m1439.l2649
and i ordered one of these for my new iwata airbrush so that i can use both airbrushes with one hose...Will this work?
http://www.ebay.com/itm/360584857696...84.m1439.l2649
