1st multi color
Old 05-16-2012, 08:13 AM
Default 1st multi color
This is my first multi color paint job with my airbrush still cant get perfect straight line cuts tho in liquid mask plus a couple small bleeds but other wise let me know what ya think.
Lightningfast13 is offline
Old 05-16-2012, 09:49 AM
Definitely would like input from all the great painters on this forum!
Old 05-16-2012, 10:55 AM
One of the biggest tips I can give you for cutting liquid mask is to cut the very tip off of your exacto knife. In other words, install a fresh blade and using a pair of wire cutters, cut the tip of the blade off so there is no more point at the end.
Also, the closer you hold the knife to parallel with the surface the straighter your lines will be.
MustangJoe413 is offline
Old 05-16-2012, 10:58 AM
hey thanks for that tip mustang.
Old 05-21-2012, 12:14 AM
bakaguyjean's Avatar
I would have used tape for this,liquid mask seems overboard. But I like the design of it and now you can run it and paint another one.
bakaguyjean is offline
