Go Back  R/C Tech Forums > General Forums > Painting, Designs, Graphics and Photography
Blank Templates for Designing On Paper >
Like Tree9Likes
Old 06-30-2005, 09:39 PM
  #136
Hi again was wondering if yuo could do the Duratrax Evader
ST for me I have attached a couple of pics of it.
plucked_camel is offline
Old 07-01-2005, 03:26 PM
  #137
cyclone's Avatar
these templates are great!!!!!!!
only problem is, im trying to design them on Ms Paint and for some reason every time it load it on i get loads of messed up lines around the edges when im tring to fill the colour????????? could any1 pleaz help me on how to make this right?
(in fact its not only your templates, its the same wih anything that i save?)
cyclone is offline
Old 07-01-2005, 04:37 PM
  #138
scoobydo's Avatar
Strange. I tried it and see what you mean.
My solution, MS Paint Sucks!
I built them to print out and work on them by hand. However, most programs (other than MS paint can handle it)
I would suggest, if you have the capabilities, to change the format to GIF or BMP and then try working on it in MS Paint. Worth a try.
If I find out anything, I will let you know.
scoobydo is offline
Old 07-01-2005, 04:40 PM
  #139
Dyer13's Avatar
You can download a free trial of photoshop, or paintshop, or you can download it for free off limewire or kazaa...
Dyer13 is offline
Old 07-01-2005, 04:44 PM
  #140
Dyer13's Avatar
that is stupid, DL photoshop...
Attached Thumbnails Blank Templates for Designing On Paper-cerrera-gt-template2-done-ms-paint.jpg
Dyer13 is offline
Old 07-01-2005, 04:47 PM
  #141
Dyer13's Avatar
The evader and the xxx-nt are one in the same...
http://img133.echo.cx/my.php?image=p...anktempla1.jpg
Dyer13 is offline
Old 07-01-2005, 05:02 PM
  #142
Ok I didn't know that, thanks.
Old 07-01-2005, 06:39 PM
  #143
scoobydo's Avatar
Yeah, I find most Stadium Trucks and Buggy Bodies to be the same all around.
If your just plotting a paint scheme, you can use most any of the templates we have.
Try This one, almost looks identical to it.
http://www.rctech.net/forum/attachme...chmentid=60133
scoobydo is offline
Old 07-01-2005, 07:00 PM
  #144
scoobydo's Avatar
So I think I know the problem.
Because I save it as a JPG, the vector art becomes pixalated when I bring it to Photoshop. That will give you very small, scattered or loose pixels. Usually not noticeable to the eye as the value is like 1% off from the 0 it should be.
Photoshop, or any program worth its mustard, will allow you to change the sensitivity settings on your Paint Bucket, Selection Tool, Magic Wand etc...
Usually, the default setting for photoshop is set to disregard such low values. However, MS paint is set to the highest setting. Meaning, that thing will pick up on SINGLE pixels. As Far As I know that cannot be changed.
You can set up photshop to do this, but that is only neccessary when making stuff like web or program icons. Even then, the image should be small enough to not even need the selection or bucket tools, you can just do it by hand (or pen tool in this case)
So there you have it. A very long explanation on why MS paint Sucks and why you should invest in Photoshop, or at least hack it.
scoobydo is offline
Old 07-02-2005, 11:42 AM
  #145
cyclone's Avatar
OK so i can get paintshop is this 1 good 2?
cyclone is offline
Old 07-02-2005, 12:28 PM
  #146
Could you create a XXX BK2, J Concepts Illuzion BK2 and a J Concepts Illuzion MF2?
Thanks,
JB
out_to_lunch is offline
Old 07-02-2005, 12:55 PM
  #147
Dyer13's Avatar
Hey scooby Doo, you know how when you are using the line tool in Photoshop the line isn't "crisp"...meaning that it gets lighter on the edges, intead of a solid color...Well I am using photoshop v.7, do you know how to change it so it doesn't do this? Also, when I delete the color inside an outline in a solid color it deletes some of the pixels on the solid color I used for the outline...do you know anyway to change it so it doesn't do that?
Dyer13 is offline
  #148
cyclone's Avatar
and if you get any time could you do a titan tc 2, But heee theres no rush!
http://i23.photobucket.com/albums/b3.../t60020001.jpg
cyclone is offline
Old 07-02-2005, 01:26 PM
  #149
Dyer13's Avatar
Here ya go....
Scooby, I figured out the answer to my other post about the sharp edges, etc...
Dyer13 is offline
Old 07-02-2005, 01:42 PM
  #150
cyclone's Avatar
nice 1 !!!!!! now ive just got to finish downloading paint shop, then a can get designing
cyclone is offline
