Newbie liquid mask Question
Hello, I am the king of the one color paint job. I want to get a little creative, but my encounters with liquid mask have not gone well. I tried applying it with a small nylon trim brush with bad results. What shoud I use?
use a brissle brush and apply in 5 or 6 thin coats and allow to dry thorouly before applying the next coat
I'm not a fan of liquid mask, but the best way to apply it is to spray it on. You mentioned that you used aa small trim brush, if you were trying to mask pinstripes or the like I would recommend that you cut thin strips of vinyl masking tape instead. You will get much better results.
Thanks.
Use a foam style brush is you are going to brush it on, works much better than one with brissles.....
Tech Legend
Trader Rating: 51 (100%+)
Re: brush
Originally posted by Slotmachine
Use a fluffy make up brush that women use to blend in thier rouge on the cheeks. I myself spray it on using a gravity feed aotomotive spray gun, 2 coats heat gun in between coats.
