spraying liquid mask...
Old 09-14-2021, 06:23 PM
  #61
lil-bump's Avatar
Trader Rating: 89 (100%+)
Originally Posted by studawg View Post
For those who are spraying liquid mask in a HVLP gun, do you have to thin it? I have a 1.5mm needle HVLP air gun from amazon and the needle kept clogging. What would be a good ratio to thin it?
To follow up on this post, I found that around 40 psi is the sweet spot and I did water down the Bittymask mixture first. Make sure to strain the liquid before putting it in your spray gun or else the lumps will for sure clog your needle.
I strain Bob dively cut with 20% hot water. I shoot mine thru a badger omni 4000 airbrush with a 1mm needle and nozzle set. Works like a charm. I shoot @ 30 psi.
I clean with soapy hot tap water between coats.
lil-bump is offline
