spraying liquid mask...
Old 04-28-2016, 04:53 AM
  #46
whitrzac's Avatar
Trader Rating: 96 (100%+)
I bought a california air air compressor.
Menards has them on sale for $150 right now.,
This video tells you everything you need to know about it.
https://www.youtube.com/watch?v=AZWqHndbkVI
Yes, it really is that quiet.
http://www.homedepot.com/p/Californi...10SE/205602927
whitrzac is offline
Old 04-28-2016, 02:27 PM
  #47
Vigilante212's Avatar
Yes they are nice and quite.
Vigilante212 is offline
Old 04-05-2017, 05:38 PM
  #48
Originally Posted by motox450r View Post
I ended up going with the 1.5mm tip and it sprayed awesome! The only issue is my small oil free compressor can't keep up with the volume the HVLP gun uses for air. I read a bunch but it sounds like I am better off with an oil free compressor. Thinking about going with this compressor. My compressor now is 1/3hp cheap one from harbor freight and just doesn't have the CFM I need. I use a filter on the line as well. Any suggestions would be great! Thanks
http://www.lowes.com/pd_470442-30449...uctId=50129758
How difficult is it to clean the gun afterwards?
RookieRacer00 is offline
Old 04-05-2017, 06:38 PM
  #49
whitrzac's Avatar
Liquid mask breaks down in water. I spend 5-10min cleaning it after I do my last coat. You never get all of it out, but spatter doesn't really effect liquid mask.
whitrzac is offline
Old 05-04-2017, 11:15 PM
  #50
Trader Rating: 17 (100%+)
Can you use this same gun for air brushing as well? Or would something with a smaller tip be better
tylem28 is offline
Old 11-13-2017, 09:38 AM
  #51
Hello,
I bought an Iwata Eclipse HP-BCS and an Olympo TC-80 automatic compressor (0 to 40 psi).
I am new so I wanted to clear some doubts.
Is it normal for the compressor to drop from 35 psi, to 20psi when I am using the airbrush? In fact, it doesn't matter what pressure do I start with, it will always drop to 20psi when I use it.
I can not get the airbrush to draw a thin line. I mean, it is not even close. From what I have seen on the internet I should get a 0.2cm line for example, and the smaller I can paint is a line of 0.7cm which is a lot!
Thanks! Hope somebody clears my mind!
Joselox is offline
Old 11-13-2017, 08:12 PM
  #52
carbongoat's Avatar
Originally Posted by Joselox View Post
Hello,
Take the very tip off airbrush. You can get a finner thin line that way. Be careful thou you can damage needle very easily because it is exposed.
carbongoat is offline
Old 11-14-2017, 08:29 AM
  #53
Originally Posted by LOW ET View Post
picked up one of these today for liquid mask (comes with the 1.4 tip). they are on sale for $9.99 with the coupon code 56395719: http://www.harborfreight.com/20-oz-8...gun-67181.html
Coupon code for this is available. Only $9.99 with coupon code.
https://www.harborfreight.com/savings_coupons.html
jmitchell is offline
Old 11-15-2017, 06:05 PM
  #54
Worked, thanks a lot!
Joselox is offline
Old 05-20-2021, 08:47 PM
  #55
Default What Happened
Has Bob Dively gone out of business? I can't find his masking film anywhere. What to replace it with???????????????
mediumquick is offline
Old 05-21-2021, 11:55 AM
  #56
I had the same question a few weeks ago when I was looking. It seems last June he had a fire and hasn't reopened.
sweems is offline
Old 05-23-2021, 02:14 PM
  #57
HarryLeach's Avatar
The Bitty masking is pretty decent.
HarryLeach is offline
Old 05-24-2021, 06:29 PM
  #58
wingracer's Avatar
Trader Rating: 24 (100%+)
It's been many many years since I used it but I had good luck with Hobbico liquid mask in the past. Local hobby shop always had it in stock so anytime I ran out of Dively and needed some now, I'd just run down there and grab a bottle.
wingracer is offline
Old 06-10-2021, 03:06 PM
  #59
For those who are spraying liquid mask in a HVLP gun, do you have to thin it? I have a 1.5mm needle HVLP air gun from amazon and the needle kept clogging. What would be a good ratio to thin it?
To follow up on this post, I found that around 40 psi is the sweet spot and I did water down the Bittymask mixture first. Make sure to strain the liquid before putting it in your spray gun or else the lumps will for sure clog your needle.
studawg is offline
Old 09-05-2021, 08:44 PM
  #60
Ackchyually's Avatar
As dead as the Dodo. Same with Parma Fasmask.
Ackchyually is offline
