69 camaro
Old 01-13-2011, 04:25 AM
Trader Rating: 16 (100%+)
Default 69 camaro
Ijust got my HPI 69 camaro, the rear end has to be installed in it.What kind of glue do I use to put it in with.Do I paint it first, or glue it in and then paint it.Any help would be nice.
jtsbell is online now
Old 01-13-2011, 04:49 AM
Blacktiger355's Avatar
Trader Rating: 81 (99%+)
I'm pretty sure it uses a few small screws and maybe some double sided tape. All done after painting.
There should be assembly instructions with the body.
Blacktiger355 is offline
Old 01-13-2011, 02:49 PM
chris moore's Avatar
Trader Rating: 90 (99%+)
In all the other HPI shells I've done thay include some double sided tape and the instructions tell you where to place the tape. However I have also found that the tape alone is sometimes not enough and I usually use some small 4/40 screws/nuts to make sure it does'nt come loose durring a race.
O and yes you should paint it first then install.
chris moore is offline
Old 10-03-2011, 03:55 PM
Default :)
hi guys im brand new to rc and am having the same problem, would love to see a step by step instalation of the shell as this is my first ever , if u have any links it would be greatly appreciated
willywagtail is offline
Old 10-05-2011, 04:22 PM
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
I take the rear piece after its cut out and everything is painted and put Shoe Goo on the 3 tabs that go inside the body. Then once in place put a couple paper clips on the side tab and body to hold it together while it dries. Once dry I take and smear a light coat of more shoe goo on the inside where the seams from the 2 pieces meet. No issues whats so ever here. Some pretty wicked rear hits to body and hasnt come undone on multiple cars.
Flying Monkey is offline
