paste picture inside body??????????
i have seen "how to" articles on gluing photos to the inside of a lexan body. has anyone ever tried this, and are there any pitfalls?
thanks, don
thanks, don
I have done that ones, I did use Shoe Goo, it works but xxx-mainīs picture glue maybe works better
/AN
/AN
nice, very nice. i'll look into xxx-main picture glue. thanks, don
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
go here and u will shown the 'AFTER RUN' picture. where the plastic sticker i use was chipped after an impact.
go here and u will be shown the 'BEFORE RUN' pictures of my car.....
in short.... maybe it is better if you use a THIN and PAPER sticker instead of using THINK PLASTIC sticker.
mop
Sorry I forgot to attach the picture.
I did it once. It's a lot of work but looks really nice.
Civic Body.
Civic Body.
how did you get the picture on the bottom of the chassis?? How is the picture protected from not getting scratched??
I used JET Glue for the picture, I put Glue in the whole picture and carefully put it in the area I decided. Then I paint the body as usual. I used Faskolor paint. Painting, that's the only way I used to protect the picture. I hope this answer your question.
as being said by andyobaez.... after the glue dried.... you will then paint your body as usual thus creating a protective layer to your picture from the water or nitro splashes that will 'kill' your pictures.
now i have additional problem after using PLASTIC STICKER.
my plastic sticker is SHRINKING become a bit smaller after sometimes.... thus revealing cracking lines along the sticker. this will cause water sippage when i wash the body with water or nitro sipage when you play your car.
SO .... again....
DONT USE PLASTIC STICKER ... only use paper.
How do you not have a hard edge around the edge of the picture when you cut it out? I guess you just have to take lots of time to cut the picture to get the edges as clean as you can... I mean, if your picture is cut out square, all you will have is a square...
How did you cut that even around the pictures?
On the civic body, I notice the area inside the girl's arm is black as well - was the picture of a girl against a black background, or did you have to cut the inside of the picture out?
mop_iko: "how did you get the picture on the bottom of the chassis??" Not to the inside of the body.....
See the picture by hgcolors
http://www.rctech.net/forum/attachme...&postid=868962
Is it a lexan under body?
/AN
/AN
