Go Back  R/C Tech Forums > General Forums > Painting, Designs, Graphics and Photography
how long do i let my paint dry before i put on protective rustoleum coating? >
Old 05-01-2010, 08:57 PM
Default how long do i let my paint dry before i put on protective rustoleum coating?
I just finished my body about an hour ago. It's dry and i would like to get one coat of rustoleum on so it can dry overnight since it takes forever to dry.
Is it ok to put it on now? or should i let the paint dry overnight? Every coat i did was dried with a heat gun.
i used 12 colors.
dreaux is offline
Old 05-02-2010, 12:44 AM
AlienModified's Avatar
I waited two days, but I didn't use a heat gun to dry it, and I used water-based acrylic. In your case, I'd at least let it sit overnight.
AlienModified is offline
Old 05-02-2010, 06:07 AM
Bfutura15's Avatar
I dry everything with a hair dryer, and wait over night to do it.
Bfutura15 is offline
Old 05-03-2010, 01:58 AM
R/C Lidz's Avatar
Trader Rating: 58 (100%+)
5 minutes...
R/C Lidz is offline
Old 05-03-2010, 04:04 AM
Czech-it-Out's Avatar
4 and a half minutes...
Czech-it-Out is offline
Old 05-03-2010, 08:20 PM
Super Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 62 (100%+)
5-10 min. for me. use a heat gun to dry the paint also.... jeremy
J.Whiting is offline
Old 05-03-2010, 11:27 PM
monkee's Avatar
Trader Rating: 15 (100%+)
what is the point of the rustoleum?
just a thick final coat to help eliminate paint ruboffs in hitting the boards?
monkee is offline
Old 05-04-2010, 12:34 PM
CaptCrunch's Avatar
Trader Rating: 17 (100%+)
Naw It's so yer body won't rust
Yep, the rustoleum is a good hard final coat. Really make a difference in my basher tests too.
CaptCrunch is offline
Old 05-05-2010, 06:52 AM
MikeXray's Avatar
Trader Rating: 73 (100%+)
I've done it with as little as 30 mins, I try to let it sit overnight if I can. Use the flat rustoleum protective paint, it drys like 500% faster, I have no idea why the gloss takes so long to dry.
MikeXray is offline
Old 05-05-2010, 11:17 AM
hotrodchevy14's Avatar
Trader Rating: 113 (100%+)
Does it work with faskolor paint also?
hotrodchevy14 is offline
Old 05-05-2010, 04:14 PM
I wait about 5 minutes. But I am using an acrylic clear coat from Krylon.
Hummer Man is offline
