What Airbrush to chose for BEGINNING RC Painting ?
#62
http://www.tcpglobal.com/airbrushdepot/abdtc16.html
Would this compressor work for this? for the Neo series Gravity Fed brush?
what else would I need besides a cleaning station and Paint?
#64
I dont know if this is the best place to ask this question but here it goes. Im just now getting into the airbrushing seen and was wondring if I need a respirator or just use a cheap dust mast? Ill be using faskolor paint. Thanx for any insight
#66
I purchased a neo and returned it to get a Eclipse up-cs. I would like to get another airbrush for sparing large areas. My question is. Would it be best to get another Iwata style brush or does it matter. I Read on here that you have to get a Iwata air line for iwata brushes. If this is the case, if I got a master or something else. Will I have to run another line to my compressor?
#71
I am looking at picking up a second airbrush.
I am debating picking up either of the following:
Iwata Revolution
Iwata HP-CS
Curious which would be better suited to spraying bodies and getting into doing fades and such. The revolution comes with the 0.5 needle and the HP-CS comes with the .35 needle. Not sure the 0.35 needle would be good for spraying paints straight from the bottle (using createx, auto-air and faskolor paints). Guessing as is the HP-CS would be best to get the 0.5 needle as well to do plain coverage work. Then use the 0.35 needle for shading.
Thanks in advance.
Iwata Revolution
Iwata HP-CS
Thanks in advance.
#72
Master and Iwata have the same size input so the same quick connect will work.
#74
I have a big air compressor in my garage that I use to work on my autos...can I use this source to paint?
#75
