XXX Lexan Picture Glue
Word of warning: When they say use a very fine grit sandpaper to rough the surface, make sure you use the finest you can fine.
I had a piece of very fine (small piece and I can't remember the grit...sorry) and it scratched the inside of the lexan more that roughed it up.
Not knocking the product, just a note from experience to make sure you have the right sandpaper.
your probably better off with something like an automotive scrub pad. i forget the actual name of them is. it's like a plastic brillo pad. it'll rough up the surface you want and shouldn't leave any scratches.
Looks like it works great though, and the picture hides the scratches better than I thought.
