Like Tree10Likes
Vinyl Cutters!
Old 04-14-2011, 12:06 AM
  #916
Rugspin's Avatar
If you plan on doing any printing of logos to be cut out then you want a contour cutting cutter.... If your just doing mask all you need is a regular cutter.... Adobe Illustrator is best to do your vector art in and is transferable to any cutter. Just save the file as an .eps
Rugspin is offline
Old 04-14-2011, 10:38 AM
  #917
crd
MH serie and Laserpoint are made by different manufacturers.
Paco
crd is offline
Old 04-20-2011, 07:39 AM
  #918
BlackLabelVinyl's Avatar
Trader Rating: 15 (94%+)
I have a Desay Masters 36" cutter and I use Illustrator as well as Photoshop for editing. The Roland Stika cutters are not supported in Windows 7 so just beware.
BlackLabelVinyl is offline
Old 04-20-2011, 02:15 PM
  #919
dodgeboy's Avatar
The SV-8 ,SV- 12 ,SV-15 and the GX-24 are supported on windows 7
Here is the link http://dg4.roland.co.jp/en/cutting.html#sx81215
dodgeboy is offline
Old 04-20-2011, 03:00 PM
  #920
Yes. Sorry, I had a SX-12 and it wasn't. Should have mentioned the model.
Old 04-23-2011, 06:03 AM
  #921
Bfutura15's Avatar
I need some help on app tape. I currently use RTape 4050RLA, but cannot seem to find any. Most all of the places have 4075RLA. This is suppose to be a high tack where mine is medium. How much more tacky will the 4075 be? I just need to make sure when I put the mask on the body it stays on the body instead of the tape.
Bfutura15 is offline
Old 04-26-2011, 04:42 PM
  #922
Rugspin's Avatar
try http://www.fellers.com
They have everything you need. might try R tape ultra clear. Its transparent and low tack for working in lexan bodies
Rugspin is offline
Old 04-27-2011, 05:50 AM
  #923
Bfutura15's Avatar
How well does it conform to the bodies?
Old 04-28-2011, 12:34 PM
  #924
Rugspin's Avatar
Works pretty well. Doesn't conform quite as well as the standard transfer tape but shure does release better and make it easier to see if your lined up.
Rugspin is offline
Old 05-14-2011, 12:27 AM
  #925
Mr_Gleeman's Avatar
Trader Rating: 16 (100%+)
Can someone please tell me if there is a plugin for Corel Draw when using the Craft Robo vinyl cutter?
John
Mr_Gleeman is offline
Old 05-14-2011, 04:11 PM
  #926
dash riprock's Avatar
John
Here you go
http://www.craftrobostore.com/craftrobodownloads.html
dash riprock is offline
Old 05-15-2011, 01:39 AM
  #927
Mr_Gleeman's Avatar
dash riprock, thank you!
John
Old 06-09-2011, 02:09 PM
  #928
Trader Rating: 64 (98%+)
Does anyone know where I can get some 8.5X11 masking that I can cut with my vinyl cutter that will go around curves easily and will withstand R/C lacquer paints?
Team Paradyme is offline
Old 06-09-2011, 08:28 PM
  #929
semi-fast's Avatar
Oracal 810 vinyl works good. They don't sell sheets that small though. You might be able to buy it by the yard at a local sign shop......
semi-fast is offline
Old 06-14-2011, 09:05 AM
  #930
Default Vinyl Mask
What vinyl mask works best on r/c bodies. the mask i have been using doesnt like to conform to the odd shapes of the bodies. but still peels clean and easy.
Roadsterdude is offline
