How to cut windshield air hole.
Old 08-21-2007, 04:37 PM
XNXIXTXRXOX's Avatar
Default How to cut windshield air hole.
What is the best way to cut the holes in the front and back windshield? I only have about a 1/2'' drimmle. Lexan scissors maybe?
XNXIXTXRXOX is offline
Old 08-21-2007, 05:18 PM
nc-hopsing's Avatar
Yup, drill a hole with your dremel to give you a place to start your cut, then use the scissors to cut it out.
nc-hopsing is offline
Old 08-21-2007, 05:23 PM
Mike Ellis's Avatar
There is a adjustable hole cutter with an exacto type blade in it available at local hobby shops.
Mike Ellis is offline
Old 08-21-2007, 06:46 PM
Zootcapri's Avatar
I use the OLFA tool bought at my LHS. It can adjust for different sizes and does a great job of scoring the hole. I generally will cut to the score line with scissors and start the flex until it comes off process. Clean up burrs with the dremel.
In a pinch I have traced a wheel the size I want with a sharpie and cut with body scissors.
Zootcapri is offline
Old 08-22-2007, 09:06 PM
BuggyKing's Avatar
Trader Rating: 17 (100%+)
I use a dremel, body scissors and X-acto.
BuggyKing is offline
Old 09-10-2007, 01:56 PM
barber's Avatar
i use a circle cutter
barber is offline
Old 09-10-2007, 02:18 PM
joe of loath's Avatar
hole saw. punch a dent with a biro and fire up the drill
joe of loath is offline
Old 09-10-2007, 02:42 PM
rcpaintfx's Avatar
I also use a circle cutter, very neat and easy.
Kev
rcpaintfx is offline
Old 09-11-2007, 06:28 PM
CurveTracer's Avatar
Default Windsheild holes
I use a 2" or 2 1/4" hole saw attached to my drill. Works nice and clean.
On the rear winndsheild I use the hole saw and elongate the opening with a dremmel tool.
I smooth all edges with a dremmel tool.
CurveTracer is offline
Old 09-18-2007, 12:25 PM
I use Forstner drill bits. They are available at about all home centers and woodworking stores. They cut very smoothly. I back the body on a piece of wood before drilling. Available in sizes from 1/8" up to very large 3 1/2-4". Not too expensive either.
jsears is offline
Old 09-18-2007, 02:56 PM
Z_Schneider's Avatar
Cut the hole with a scissors and dremel the edges smooth.
Z_Schneider is offline
Old 09-18-2007, 05:29 PM
I use a circle stencil that I got from the art store. I use the circle that is just below 60mm. Once I draw the circle on the front/rear windows, I use a reamer just to start a small hole for the cuts. I then use my sissors and start from the hole that I reamed out and cut to the point of where I made the circles with my sharpie pen. If you cut clean enough, you don't have to bust out the dremel tool for smoothening out the rough edges.
Paul D. is offline
Old 09-18-2007, 09:27 PM
SlamMan's Avatar
Save the headache and spend the 6 bucks on this circle cutter. You'll wonder how you cut bodies without it.
http://www2.towerhobbies.com/cgi-bin...&I=LXHEA0&P=ML
Cuts perfect wheel wells and fuel holes in seconds. Just score and snap it out.
SlamMan is offline
Old 09-20-2007, 01:58 AM
hpipro4's Avatar
Trader Rating: 100 (100%+)
yeah the hobbico circle cutter is good for cutting wheel wells and basicly any holes since it adjustable and also comes with exxtra blades and pencil lead for using as compass.....
eddie
hpipro4 is offline
