SpazStix color change paint?
Has anyone used SpazStix colorchange paint? I'm using it for the first time and it appears to be very transperant. I was wondering if i'm doing something wrong, or if this is normal. I've applied 2 coats and im spraying at 20 psi but I can barely see the paint, im using paint # SW1060.
Thanks,
Thanks,
It is very transparent. You should see the particles in the paint though and you need to shake it up each time you spray it. If you been shaking it, then spray two more coats and back it with Fascolor black, then you will see the color pop.
I shot a couple more coats, but Im not getting that deep colorchange effect Im looking for. Maby i will try a couple more coats. for a total of 6.
You wont get the effect until you spray the black
They turn out good but are limited in color. Everything turns either green or blue. You spray them the same way, with about 4 top coats and then you back them with faskolor black.
