Airbrush spit water..:(
I just bought a iwata esclipse HP-CS airbrush kit with air compressor off from ebay for brand new. Had no problem with spray color in thin to thick and bold to fade but sometime it spit water. What would cause this? Does it has something to do with the air compressor?
-Dustin
-Dustin
You need a moisture trap. This will filter out the moisture in the air as you spray. The more your compressor works, the hotter it will get and the more moisture will saturate the air being held in the compressor.
Check out this link.
Funny thing is i do have the moisture trap but it still spit water. I can see them fill up with moisture in it. Bad air compressor or bad moisture trap? Here the link i bought the air compressor along with the airbrushes.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=200117718445
My guess is the air compressor is no good. Maybe i should get a iwata air compressor or do you have a suggestion on better one?
does your compressor have a drain plug in it? if so turn your compressor off drain all the air out, then unscrew the drain plug and let the water drain out.
One time I had about 3 gallons of water in my 20 gallon air compressor tank. sometimes sediment builds up and plugs this hole, so you might have to stick a screw driver in it to clear it out.
there should be nothing wrong with the brush or the compressor, as was said earlier the more the compresor heats up the more likely you are to get mouisture in the air coming out of it due to condensation in the line as the air cools off.
you also need to drain the mouisture trap when you see it start to build up water in the bowl.
I'm guessing you live in an area with high humidity as well this will also give you some problems as well if that is the case.
Yep. Just condensation in the air/hose. Easy fix.. Nice airbrush set up you got by the way!
Yeah i am living in area where the humidity is high. I have clear out all the little water that stick onto moisture trap wall inside. Still spit water once in a while. Will this extra moisture trap help?
http://www2.towerhobbies.com/cgi-bin...?&I=LXDD65&P=7
im not sure what type/brand of compressor you got do you do it by the tap you plug the air line in or the drain tap if it has one
one thing i couldn't tell from your post is if you drain it when the tank is fully compressed or not its best to do it when it is full the pressure help's blow the water out better then an emty tank with just the pump pressure blowing it out
if your tank hasn't been drained in a while, I seriously don't recomend draining it at full pressure. Unless you like being showered by rust colored water at a high velocity.
If iT's an older compressor, it is going to have rust inside. because if you think about it like this. your tank is most likely made of steal, water builds up and your pumping air into the tank. Water + Air = Rust. It's a mess, I know because I watched a highschool kid try to drain our compressor at work. It was at full pressure, and he got the wort rust colored shower I've ever seen.
Funny stuff though
Funny stuff though
Guys... if you look at the third post there is a link to the equipment he bought. It isn't a tank type compressor, it's a small airbrush type compressor.
whats more then likely happening is that the compressor is heating up so much that the air doesn't have enough time to cool the air before it leaves the moisture trap and is cooling down in the hose/metal body of the airbrush and is forming condensation well after the moisture trap.
there are several things you can do to correct this problem.
1> add an inline moisture trap about a foot before the end of the hose nearest the brush.
2> add an air storage tank with the moisture trap relocated to the output of the new tank. tanks can be found at kmart walmart HD and llowes and most auto part chain stores.
3> get a 10foot section of air line from your local home depot or lowes or plumbing supply and relocate the mouistre trap to the end of that hose and connect you airbrush hose to the trap.
while not the most elegant of solutions any of the three above should eliminate your moisture problems.
