Go Back  R/C Tech Forums > General Forums > Painting, Designs, Graphics and Photography
how to Dye Tamiya Suzuki Swift rims ?? >
Old 06-02-2007, 08:54 PM
Trader Rating: 118 (100%+)
Default how to Dye Tamiya Suzuki Swift rims ??
Does anyone know how?? I have tried and tried, boiling hot water, even let them sit in there for 2 hours and the dye did not take at all.
Is there a special trick to do this??
Please help!
thanks,
Chris
Chris Furman is offline
Old 06-02-2007, 09:28 PM
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I am asuming you're using RIT dye?
Maybe youre not using enough Dye in the water?
Maybe wach the rims with dish soap to remove any molding release agents?
I have dyed the swift wheels with much success with hot hot hot water with nor real problems.
andrewdoherty is offline
Old 06-07-2007, 03:13 PM
HardLuckRacing's Avatar
couldn't get them to work either.. i figured it was because the swift rims were a different type of plastic and will not dye.. ended up just painting them
HardLuckRacing is offline
Old 06-07-2007, 03:26 PM
Paradoxmaker's Avatar
If they won't dye then they are probably ABS plastic instead of Nylon.
Paradoxmaker is offline
