faskoat/ fasglitter?
Old 02-10-2007, 09:46 PM
Default faskoat/ fasglitter?
hey i have an iwata hp-ch and tried spraying fasglitter, mixxed as per instructions 1 vial one 2 oz bottle and sprayed at 40 psi (large area) and it kept clogging the tip whats wrong? whats this called? can you stop its? cheers, Josh P
aus jd 2703 is offline
Old 02-10-2007, 10:15 PM
Trader Rating: 91 (100%+)
I've never used it myself but from what I hear it should only be shot through a brush with a very large tip, like the biggest one a Paashe VL comes with, which is about three times the size of a HP-CH, and even then it is difficult to work with.
Eric Tomczyk is offline
Old 02-10-2007, 11:46 PM
losi guy's Avatar
Trader Rating: 38 (100%+)
you need to change the tip in your airbrush. Instructions should tell you what tip you should use.
losi guy is offline
Old 02-11-2007, 12:52 AM
yeh ive got an old cheapo airbrush did the trick but wondered if i could use my iwata
Old 02-11-2007, 06:26 AM
Kropy's Avatar
Just ues your old "Cheapo", It's not worth taking the chance with your Iwata, This is what I use to spray the FasGlitter.
http://www2.northerntool.com/product..._200307207.htm
Kropy is offline
Old 02-11-2007, 10:32 AM
If you want a really cheapo touch up gun like the one Kropy linked, Harbor Frieght has one for about $15.00! Probobly sucks for real painting, but shooting Fasglitter isn't about fine atomization.
