repainting a body
Old 01-19-2007, 04:02 PM
Default repainting a body
I recently purchased a car and would like to repaint the body. The body was painted a solid color on the inside. Is there any way to remove the paint and start over?
Is it the practice of most painters to paint the inside of the body instead of the outside?
Would it be better to purchase a new body and start from scratch?
highflyin7 is offline
Old 01-19-2007, 04:13 PM
20 SMOKE's Avatar
Trader Rating: 102 (100%+)
i have herd guys using nitro fuel or non acetone finger nail polish remover try a small spot first like the wing
20 SMOKE is offline
Old 01-19-2007, 05:09 PM
monstergecko's Avatar
you will get better results and easier to just buy a new body... But if you want to give this a try it works ok(i did this to fix a body that I messed up while painting) but the plastic seems to get britle faster. Soak the body with brake fluid for a while the paint peels right off. the clear lexan gets hazy and a little bit more britle. And brake fluid is nasty stuff to work with...
Cheers,
MG
monstergecko is offline
Old 01-19-2007, 05:47 PM
Practice and try painting the outside. You may be suprised.
calvin3 is offline
Old 01-28-2007, 04:43 PM
Ian75rc's Avatar
I have tried it. Two colors - green and black. I use with some fine sand papers before spray. But so far not all color will stays intact. My shines green paint part peeling off after few run - when being scratch by other cars but my flat black color part stays.
Ian75rc is offline
Old 01-28-2007, 05:41 PM
Kcdzim's Avatar
What kind of paint are you using? It shouldn't necessarily peel. It should get scratched and worn off though, which is why you specifically don't paint the outside and instead paint the inside of lexan bodies.
Kcdzim is offline
