FASMASK
Old 12-27-2006, 08:19 AM
Default FASMASK
hi folks hope you all had a good chrissy.
im going to use some fasmask liquid mask for the first time
1. is it ok
2.can you leave it on for along time say if you paint a shell over a week or will i have probs
3.when i used masking tape i cut to deep and the shells kept splitting is this easier to cut
4 by the way could somebody run through how to get carbon fibre effect please
any comments please
cheers
T2 SLOW is offline
Old 12-27-2006, 09:26 AM
TRFTIM's Avatar
Seems ok fasmask but i always use bob diveley with no problem.
have alook at http://www.cfxpaintworks.com/modules.php?name=Forums
TRFTIM is offline
Old 12-27-2006, 03:51 PM
RCSteve93's Avatar
I use it. Since I got a 32oz bottle from my dad I have been using it alot and learned how to make it as good as Bob Dively Liquid Mask.
Answers to your questions...
1. Yes, but Bob Dively Liquid Mask does not require as many coats and drys faster that Fasmask.
2. Of coarse, you can leave it on for a month if you need to.
3. Yes, liquid mask allows you to make clean lines. You just need to cut using the wieght of the X-Acto and your hand, don't apply to much pressure!!
4. For the Carbon Fiber effect I would check out... www.cfxpaintworks.com, they have many torutles and members to help you out.
Some other stuff...
Apply 5-6 coats of it. On each coat apply it a different way so coats intersect. Use a paint brush between 0.5-1 inches so you can get into hard to reach places and dip it into the bottle. Do not use a hair dryer or heat gun to dry it faster, it will warp and fog the lexan for some odd reason. Also it even can stick to the body like glue to it if you heat it, I have heard.
RCSteve93 is offline
Old 12-28-2006, 04:16 AM
thanks for the answers guysill give it ago.
cheers
T2 SLOW is offline
Old 12-29-2006, 05:19 AM
32819toon's Avatar
Hi,
I have discovered Fasmask and most of you guys say Bob Diveleys is better. If this is true it must be fantastic !! I love the Fasmask and I only apply 3 coats and have no problem peeling it off. I dry it with a hairdryer and the lexan doesn't fog.
32819toon is offline
