Paint mask
Old 12-24-2006, 04:50 AM
Default Paint mask
Hi all im looking for something I can use as a paint mask, I would like to be able to either draw on it or use it in a printer to apply a design to it, then be able to cut it up as required, stick it to my car body as a mask, paint over it and be able to remove it easily, anything like this available? thanks
Apexs is offline
Old 12-24-2006, 07:24 PM
Kcdzim's Avatar
blank vinyl sheets are available from parma or xxxmain, which is the same material as their vinyl masks, and are available from your LHS, generally. Or, you can find a automotive paint supply place and they'll usually have the larger rolls of vinyl that ends up costing less in the long run.
Kcdzim is offline
