Body Post Holes
the easiest way to cut the holes is with a reamer like this
http://www.hudy.net/eshop/products/p...7&kategoria=65
then cut out all the holes before you paint as its much easier then when its painted
-Zac
i have found out the best way to do it is mark the body post holes with the Trinity No Brainer Body Markers
http://teamtrinity.com/shop/bodies.html
and then i use either a dremel with cone shaped bit or use a body reamer -
the trick is the no brainers - makes your life so much easier....
posts
I usually just rest the body on the car approx and mark with sharpie and use a reamer like the hudy one. Also if you don't really care, you can pick up a reamer at your local hardware store, for like 6 dollars, its a little longer than the RC one and has a plastic handle, but still sharp as hell and does the same job. If the body is painted, I sometimes cut out little squares of double sided tape and place the gently on the tips of the posts and once its is aligned just press down and when you take the body away it is stuck there and you have your place to put the hole.... hope this helps..
