Can someone Vacuum a Shell for me?
#16
Originally Posted by xlgraphicspro
It's actually easier than you'd think to make your own vacuum former. I did it, and was actually making aftermarket bodies for the X-5 4 wheel drive buggy. but I couldn't keep up with some of the demand, and the cost Versus the profit wasn't enough to encourage further development.
I now have a real vacuum former at work, and am able to do small projects for myself! It's really handy! If you have any questions, I can help answer some!
What was the bulk of your cost, that made it prohibitive to further production?
#17
Kinda hard to see in this photo, but it doesn't look like there is a great deal of turbulence at that rear shock tower hump. I'm going to leave it as it is. The analysis didn't come to full convergence, but the vector at the hump was in the process of straightening out as the solution converged, so I suspect it would only get better.
I ran the analysis first without the wing, just to see it run. Seems like an impressive amoutn of downforce for the amount of drag. Then again, I don't have another model to compare to (anyone have an IGS file of a sedan?).
#18
Impressive numbers Sammy. Could you possibly run it again at 50mph?
When you get a few units ready for paint and mounting, I'll have paypal ready for at least 1.
Tony
Tony
#19
Tony
Tony
I'm running another one at 30mph with the wing. Then I'll try it at 50. Takes about an hour to run so hopefully I'll have both runs done by this afternoon.
#20
Geez took me forever to figure out that you can't put a 0.075 mesh on a 0.050 thick wing! Finally got 50 iterations to run, though. Solution is more realistic than previous.
About a pound of drag and 2 lbs of downforce. Seems more realistic. Rear wing seems a little unimposing, though. Especially when compared to the front. Running a much more aggressive wing overnight. Results to be posted in the AM.
The airflow seems to glide right over all the geometry in the center section. Including the potentially worriesome rear shock tower hump.
So I'm thinking the main design challenge in fitting a LMP body to a touring car is clearing the front shock towers without creating massive front downforce that can't be overcome with an adequately sized rear wing. Make a heck of a small track body, though!
#21
I might be able to help you out on forming your body..just drop me a line at [email protected], I have a nice factory built unit that I pull spoilers off of for my 1/4 scale cars.
#24
Oh man, that Courage is hot! I need a cigar!
Is that made for a touring car, though? Doesn't seem like it would clear the shock towers in the front and rear.
GResults, once I get this mold finished, if it looks like a vacform machine isn't going to show up anytime soon, I may get with you to pull a few bodies to get us started.
#25
Its made for the Tamiya F103GT (2WD, No Shock Towers): http://www.tamiyausa.com/product/ite...oduct-id=58367
#26
#28
Yeah a few years back Tamiya did a few Le Mans cars.
- Toyota GT-ONE
- Audi R8
- Porsche 911 GT1
- Nissan R390GT1
The first three were for the first F103's but the R390 was for a touring car chassis.
- Toyota GT-ONE
- Audi R8
- Porsche 911 GT1
- Nissan R390GT1
I still wonder who made that Porsche in the pic above?
#29
Finally got convergence and the numbers have changed. Also finally got it to run at 5mm ride height. This reduces the downforce numbers tremendously. No joke here, get the body as low as possible for max downforce! I might run another simulation at 6mm to see what just 1mm does, with no other changes.
@30mph:
Drag: 0.80lbf
Downforce: 0.35lbf
Center of pressure: 4.5" behind front wheels (56% front balance) and approx 3/4" from the ground. I was really surprised to find that the center of pressure was that low. If this body doesn't generate another ounce of downforce vs the Mazda and Stratuses of the world, the low CP alone might help you realize some noteable gains in stability and cornering ability.
Trace Lines show that the rear shock tower hump isn't bad at all. Might even be accelerating the air a bit before going beneath the wing. The wing seems high enough to capture any air that gets catapulted by it.
@30mph:
Drag: 0.80lbf
Downforce: 0.35lbf
#30
Hey Sam, any news of late? How are things going with the shell?
