createx paint
Old 09-27-2019, 05:43 PM
Default createx paint
Any ideas on how to make it stick better? Last time I tried I had LOTS of flaking....
FlatSix914 is offline
Old 09-27-2019, 06:54 PM
If you put it on too dry, it can't stick. Try wetter coats.
mooby64 is offline
Old 09-29-2019, 04:44 PM
Thanks! I'll give it a try.
Old 10-03-2019, 09:52 AM
Caci623's Avatar
Hi
The Golden Rule for all paints is quite simple. “PAINT WANTS TO STICK TO PAINT”. Applying the paint thick is NOT the way to go. Think of an egg. It’s only hard on the outside. When you paint thick the paint will form an outer skin thus allowing the wet paint under it to start sticking to itself. You’ve heard the “Dry to the touch”. The solution is simple. Spray your first few coats VERY thin. MIST it on and let it dry. It will look like crap but that is fine. Once they are dry, successive thicker coats will have paint to stick to. I sell 50 plus bodies a year and don’t get complaints.
Hope this helps
Caci623
Caci623 is offline
Old 10-06-2019, 05:19 AM
carbongoat's Avatar
Scuff with gray 3m scotchbrite also
carbongoat is offline
