Carbon Pit Boards
Is anyone out there making any cool Carbon Pit boards?
+2 or anything carbon fiber...
You can buy a normal pit board at put a carbon wrap on it... Although it won't be perfectly smooth.
Check out Areomax . They make some great tool and the pit board is like jewelry.
A LED pitboard is better
Look close to the Arrowmax. Basically it has a honycomb frame made from aluminium with on top a thin layer of carbon and on the bottom a sheet of lexan. The aluminium frame can be made by a CNC machine or a watercutter and thin (0.5mm) carbon sheet is not that expensive.
You can get variously sized carbon sheet from eBay. May be worth making your own if it’s decent quality.
Would anyone be interested in a Pit Board like this? Would be 6mm carbon with bubble levels on both x and y-axis, and adjustable legs to achieve a level surface. This is just a render mind you
Pilot RC products has a fully carbon pit board.
check www.pilotrcproducts.com
