Like Tree2Likes
  • 1 Post By belewis01
  • 1 Post By the rc guy
Input on a compressor
Old 02-13-2018, 04:02 PM
JPAPA26's Avatar
Default Input on a compressor
Couple questions for air brushing (newbie)
Just looking to paint a few bodies for myself
I see a few on ebay $30-50 range are they all china junk?
I have a small pan cake compressor should I get a regulator and a dryer and convert that?
Not really looking to spend more than $75 if possible
Any thoughts thanks guys
JPAPA26 is offline
Old 02-13-2018, 10:26 PM
If your compressor can supply a steady 40 PSI or so, I would start with that. I don't think a dryer is required, I would get a regulator with a water trap to start. Do some test sprays at various pressures, between 25 to 35 psi, I like to use a clipboard with white printer paper to adjust my brushes. Fastcolor, Createx, Autoair should all spray at these pressure straight out of the bottle.
JPAPA26 likes this.
belewis01 is offline
Old 02-14-2018, 02:03 AM
the rc guy's Avatar
yes jpapa use the comp you have.. i also run my garage comp with regulator and a air drier for my painting..you will find air pressure needed will vary from paint to paint..from 12 to 60 psi.
JPAPA26 likes this.
the rc guy is offline
Old 02-14-2018, 03:08 AM
JPAPA26's Avatar
thanks guys for the input.
JPAPA26 is offline
