paintwork
paintwork
can anyone tell me the best way to prepare a lexan body befor painting.any other tips on finishing would be appreciated. thank billy.
First, mark body post holes. Next, you cover the outside with plastic film(if it doesnt have it), wash the inside with hot water and last apply the window masks. Then, spray away! Cut out the wheel wells using lexan sissors and, or a x-acto knife, once dry. Another trick is to take a fine sharpy and go over the cutting indents with it so there easyer to see. Once completed pull of plastic film off the outside. To apply decals, use a towel to wipe the section your working on so its clean. then cut out the decal and apply. Make sure it contours the body curves and theres no air bubbles. Then have fun cracking, bashing and scraching your new body on the asphalt, curb, track barrier or dirt. This is body pianting in a nut shell. The End
