Go Back  R/C Tech Forums > General Forums > Oval, Larger Scales and More
how to adjust tight in and loose off >
Like Tree1Likes
  • 1 Post By kdad
Old 12-11-2016, 09:34 PM
Default how to adjust tight in and loose off
im running sc5m open mod. but i am tight in and loose off trying to figure out what type adjustments to make to smooth this out.
please help and input
js697900 is offline
Old 12-13-2016, 08:08 AM
Moderator
Packfan's Avatar
Trader Rating: 126 (100%+)
I found the following while searching through many websites and compiled the following list. I actually have it laminated and keep it in my pit box. I pretty much know what to do for adjustments but the list lets me be sure I have done everything I can. Hope this helps.
Rear Toe Cheat Sheet:
Tight on Entry - Increase LR Toe In
Loose on Entry - Decrease LR Toe In
Tight on Exit - Decrease RR Toe In
Loose on Exit - Increase RR Toe In
Basic Spring Adjustment Cheat Sheet
Loose In: Stiffer RF Spring
Tight In: Softer RF Spring
Loose Off: Stiffer LR Spring, Softer RR Spring
Tight Off: Softer LR Spring, Stiffer RR Spring
(Stiffer RF Spring will tend to tighten up the car all around the track)
Front Toe In - Less turn in steering, more exit steering, more aggressive down the straights, sometimes twitchy or darty feeling.
Front Toe Out - More turn in steering, less exit steering, more balanced down the straights, usually the most comfortable feel.
Packfan is offline
Old 12-25-2016, 03:42 PM
Trader Rating: 95 (100%+)
Default Cheat sheet
I think your toe adjustments are backwards. When you enter a corner the weight is tranferring to the right side . To help entering and through the corner you need to be adjusting the RR . As you exit the corner the weight will be transferring off the front so the left rear will come into play. You spring cheat sheet is accurate . Shock oil can help a lot and I will change it when I think I need a spring change.
latemodel13 is offline
Old 12-25-2016, 04:32 PM
Moderator
Packfan's Avatar
I took these right from Matt Murphy's tuning guide for oval. They are correct.
Chapter 4 - Toe, Camber, Caster, and Wheel Spacing
Toe
Toe is a word that describes the angle of a particular wheel, relative to the centerline of the chassis. Toe in refers to when the front edge of the wheel is closer to the centerline than the rear edge of the wheel. Toe out refers to when the rear edge of the wheel is closer to the centerline than the front edge of the wheel.
Front Toe
Front toe is adjustable by lengthening or shortening the steering turnbuckles. Front toe should ALWAYS be set after your camber and chassis heights have been set. Front toe is typically measured using a ruler, calipers, or other measuring device. In general, I like to consider front toe as a setting, rather than an adjustment. Although you can adjust your front toe to be toed in, neutral, or toed out, I like to keep things simple by always running a very slight amount of front toe out. For 1/10th scale cars, I run 1/16” of toe out (.063”). For 1/8th scale cars, I run 1/8” of toe out (.125”). Again this is something I use as a setting, and I literally never adjust the amount of front toe; however you must check your toe after each camber, chassis height, caster, or camber link adjustment. All of these adjustments play a role in what length steering turnbuckles you must have for proper front toe.
If you decide to tune with front toe, here is a basic guide to what each adjustment does:
Rear Toe
Rear toe is adjustable by changing the rear toe blocks and/or the holes through which they mount to the chassis. Rear Toe is measured in degrees. In general, the more toe in you run, the less overall steering you will have. The lesser the amount of toe in you run, the more overall steering you will have. In dirt oval cars, rear toe technology has evolved greatly over the past 4-5 years. Now it is somewhat common to run up to 6 degrees of left rear toe in, and sometimes racers even run right rear toe out! One very tricky aspect to tuning your dirt oval chassis and its rear toe in setting is that each corner affects the car differently.
Left Rear Toe
Left Rear Toe is ALWAYS run toed in on today’s dirt oval chassis. Typical amounts of RR Toe in are between 0 and 6 degrees. In general, we use the LR toe angle to adjust how the car ENTERS the corner. The more degrees that the LR is toed in, the more rotation the chassis will have on corner entry, both on and off power. The fewer degrees that the LR is toed in, the less rotation the chassis will have on corner entry. Foam tire setups often run between 1-3 degrees of LR Toe in, while Buggy tire setups often use 4-6 degrees of LR toe in.
Right Rear Toe
Right rear toe is usually set at fewer degrees than the LR, and sometimes in extreme conditions, is even run toed out. Typical amounts of RR toe are between 3 degrees of toe in and 3 degrees of toe out. In general, we use the RR toe angle to adjust how the car EXITS the corner. The more degrees that the RR tire is toed in, the more forward drive, and less on throttle rotation the car will have. The fewer degrees that the RR is toed in, the less forward drive, and more on throttle rotation the car will have. Foam tire setups often run between -1 to +3 degrees of RR Toe, while Buggy tire setups often use 0-4 degrees of RR toe in.
Camber
Camber is the angle of the wheel and tire in relation to the ground or flat surface. This is measured using a Camber Gauge. If the tire leans in towards the centerline of the chassis at the top it has negative camber. If the tire leans out at the top it has positive camber. The camber link controls the position of the wheel and tire as it moves up and down through its suspension travel. Camber is adjusted by lengthening or shortening the camber link turnbuckle until the desired camber angle is achieved. Camber has a tremendous effect on how the tires react and provide grip on the surface you are running on.
Foam Tires
With foam tires, the tire has a consistent density throughout the tire, and running higher camber angles will usually increase tire wear and create a wear situation known as “coning”. This situation also results in a reduced amount of contact patch resulting in a reduction of available traction for that particular tire. With foam tires, the goal is to set your camber so that all 4 tires wear evenly. My foam tire cars usually have the tops of both front tires leaning towards the right, and the tops of both rear tires leaning to the left. I read my tire wear after each run, and adjust my camber link length accordingly, in an effort to have all 4 tires wearing flat.
Rubber Tires
With rubber tires, the tires have foam inserts which act like air pressure, and often gain more grip when the camber settings force the tire to transfer the cornering forces to the inside edge of the tires. More negative camber on the right front wheel produces more steering and is more responsive. Less negative camber on the right front will have less steering but will be smoother. To a point, more front positive camber on the left front wheel will give better steering into and out of a turn. Less positive camber will similarly smooth out the steering but be less responsive. Typically, with rubber tires, all four wheels will have the top of the tire leaning to the left.
Camber Cheat Sheet:
Foam Tires
LF - Negative 1*
RF - Positive 1*
LR - Positive 1*
RR - Negative 1*
Rubber Tires
LF - Positive 1.5*
RF - Negative 1.5*
LR - Positive 2*
RR - Negative 2*
Caster
Caster is the angle of your kingpin relative to an imaginary line perpendicular to the chassis plate. If you were to look at your chassis, and draw an imaginary line through the middle of your kingpin, and then measure the angle between the kingpin and a line perpendicular to the chassis plate, the measured angle would be your caster angle. Total caster is figured by adding your kick-up angle and your caster block angle, to come up with total caster. We will get into kick-up in a later chapter, but for now, we will focus on total caster and its effects on chassis handling.
What Does Caster Do?
Caster affects the handling of your chassis in two ways: Straight Line stability and Camber increase as steering input is given.
Straight Line Stability
The higher degree of Caster you run, the more the car will want to stay straight while driving straight. The lesser degree of Caster you run, the more the car may want to wander while driving straight. Typically, more caster is better for straight line stability in low bite conditions and less caster can keep a car from feeling numb in high bite situations.
Camber Increase via Steering Input
As you turn the wheels, the angle of Caster affects the angle of camber. The greater the amount of caster you run, the more camber you will gain with steering input. The lesser the amount of caster you run, the less camber gain you will achieve with steering input. Generally speaking, as you increase caster, you will gain steering as a result of increased camber. This is not an absolute scenario however; because if you have too much camber gain, you can actually reduce the amount of traction that a particular wheel can make causing the tire to be overloaded and slip. In some conditions, Caster may need to be reduced, to reduce camber gain via steering input, in order to increase contact patch on a particular corner which can result in improved grip for that particular tire. Like any adjustment, too much caster can be a bad thing. The goal when tuning with caster is to find the ideal handling characteristics both in a straight line and while cornering.
Caster Split
Caster Split is the difference between LF and RF caster angles. Typically, I suggest no more than 5 degrees of Caster Split. Five degrees of caster split is achieved by running 5 degrees less caster on the LF than the RF. Caster split helps the car turn into the corner easier, and in most instances, increases mid corner steering. Caster Split usually allows a racer to run less steering throw or dual rate, which in turn reduces corner speed scrub. In some extreme situations, racers have been running very aggressive rear toe settings, and in order to make these setups easier to drive, have been running negative Caster Split. Negative Split is when the RF has less caster than the LF. I suggest that racers keep caster adjustments simple, and run either 0 or 5 degrees of caster split for a balanced, easy to drive race car.
Wheel Spacing
Wheel Spacing is an easy way to change the way your chassis drives, without changing the balance of your chassis. Front Wheel Spacing has a greater effect off power during corner entry, while rear wheel spacing has a greater effect on power during corner exit.
Front Spacing
In general, as you space your front wheels to the right, you tighten up corner entry. Spacing your front wheels to the left will free up your corner entry.
Tighter entry = easier to drive but less potential for corner speed
Freer entry = harder to drive but more potential for corner speed
Rear Spacing
In general, as you space your rear wheels to the right, you free up corner exit. Spacing your rear wheels to the left will tighten up your corner exit.
Tighter exit = More forward drive and less on throttle rotation
Freer exit = More on throttle rotation and less forward drive
Packfan is offline
Old 12-26-2016, 10:09 AM
For setup tips look at custom works setup seminar from 2013 chili bowl. rear toe is about 10 minutes in on part 3. It's on youtube by dozer cam . A lot of people trust what others say and it sometimes simply isn't true. I have been in racing in many forms for most of my life and have got bad advice from some people that I couldn't believe didn't fully understand how things work. It's really all about weight transfer . Part of being a good racer is filtering through the Bullchit. Hope this helps.
Old 12-27-2016, 03:17 AM
Ovaloldtimer's Avatar
Fix your tight in and loose off will fix itself
Ovaloldtimer is offline
Old 02-09-2017, 07:59 PM
Packfan is absolutely correct .
Left rear toe gets you in
Right rear toe gets you out
Packfan likes this.
kdad is offline
