Go Back  R/C Tech Forums > General Forums > Oval, Larger Scales and More
Losi 22 3.0 in Lm Dirt Oval >
Like Tree1Likes
  • 1 Post By Cambria05
Old 06-18-2016, 09:42 PM
Cambria05's Avatar
Default Losi 22 3.0 in Lm Dirt Oval
I am wanting to convert my Losi 22 3.0 buggy into a late model but I have no idea where to start. My biggest problem is finding some way to mount the body. Also A front guard for the body and maybe even a Lm body suggestion. From what I can tell, all the body are very similar but any suggestion will help.
Cambria05 is offline
Old 06-19-2016, 05:12 AM
Have a look if the 22t ST front shock tower/body mount would fit. Not sure if it'll be a straight fit but some wrangling may result in success....Maybe?
roadhog29389 is offline
Old 06-19-2016, 05:26 AM
Ovaloldtimer's Avatar
http://www.speedysracingparts.com/Losi_XXX-CR_Buggy.htm
Theses parts probably can be made work
body hands down the Onstat Bullet
http://www.onstatracing.com/
Ovaloldtimer is offline
Old 06-19-2016, 03:12 PM
Cambria05's Avatar
After doing some research I bought the front and rear mounts to a losi scte. From what I read you have do some adjusting but I will see once they come in. Thanks for the references though guys
beadlock327 likes this.
Old 06-23-2016, 05:09 AM
Trader Rating: 14 (100%+)
rpm makes a front bumper i used on mine, you have to drill the four holes up front and grind the edges off but works fine. The back just use the sct rear bumper its great. I did move the body mount back a some other wise it hits the window area.
dirtmod is offline
Old 06-27-2016, 04:10 AM
pm returned.
dirtmod is offline
