Go Back  R/C Tech Forums > General Forums > Oval, Larger Scales and More
FG 1/5 Sportsline Steering/Throttle problem >
Old 01-12-2015, 10:54 PM
Questions?? FG 1/5 Sportsline Steering/Throttle problem
Hi guys,
I havn't been able to find anything about this anywhere so I hope one/some of you can help me with this.
I have this RC Gas car runs fine and steers fine, but as soon as I steer to the left, the throttle is not working, the servo motor does not do anything, it just sits stuck, as soon as I restart the car buy flipping the switch Off->On the throttle works again, but just till I turn left.
Do anyone have a clue what might cause this issue?
raskjeldsen is offline
Old 01-13-2015, 10:21 AM
GT2NITRO's Avatar
Originally Posted by raskjeldsen
Hi guys,
I have 2 thoughts, try rebinding your radio:don't forget to apply the brakes, you may also have a mixing issue if you're radio is programmable hope this helps
GT2NITRO is offline
Old 01-13-2015, 02:40 PM
It does sound like a mixing problem with your radio. Review your owners manual for your radio and make sure you did not accidently mix the steering and throttle channels.
nitrohead5300 is offline
Old 01-14-2015, 04:02 PM
Thanks for your replies, sadly I'm not able to test it before in a couple of weeks since I'm currently in another country, anyways it's quite weird if it would be the channels, since I bought it used, worked all fine for a few hours of driving, but then it started to mess up, and since it's only when i turn left...
Old 01-14-2015, 06:21 PM
What brand radio came with the kit??
Old 01-21-2015, 04:41 PM
Try a fresh battery as well.
PegLeg is offline
