SCZ E290 Competition engine 9HP!
SCZ engine is a competition engine for 1/5 remote control car.
It has 29CC will give you 9 House power,on-load states limit speed over 21400RPM,and idle over 24000RPM,it’s almost perfect throttle curve.No matter in the racing road or amateur practice car,it will give you surging power and good control experience.
After three months of testing,all data of SCZ engine are excellent.
●4 bolt middle cylinder,high flow scavenging air duct and exhaust port.and it is use ceramic coating,strong lubricity、good heat resistance and long life.
●Cylinder head use high silicon aluminium square billet,it has 5 bolt head ,Precision machined from CNC.adjustable compression ratio.
●Crankshaft connecting rod is use forging technology,balance weight is perfect with the route.
●Light weight piston and pins.
●Connecting-rod bearing is use High-performance needle roller bearing from Gemany.
●Crankcase is use silence high speed bearing and high temperature resistant oil seal.
●0.3MM reed valve.
●This engine casing is aluminum alloy casting.and then precision machined from CNC to weight reduction.with a very good strength,it will guarantee in slope and extreme off-road conditions will not appear damage of engine.
●Wind scooper is use special material fiber compound.
●We strictly control every engine’s quality inspection to
●0.3MM reed valve.
9 house power. wow, houses are big, so i guess they make a lot of power........
I wanna see it in action.
