losi slider on dirt help
I would like to race my losi slider on a dirt oval track and have no idea how to set it up at all any advice will help
It is a stock class but we run brushless systems in them everything else has to be stock
Jake here's u a starting point... Stock springs 35 wt fluid.... -1 camber on both right front and rear ..... 0 degree camber on left front and rear... Middle hole on the shock towewrs.. that should get u started . U will have to make adjustments each round so be prepared and u will have to let off the throttle in the turns. Can't drive it full throttle in turns!!!!!!!
Ok i will try that. I have 40wt oil in it right now so i will replace it with 35. What diff should i use ball or gear?
Use what I have now... Get some laps and experience and then worry bout fine tuning.everyone's preferences are different. My reccomendation is buy the xxx main setup guide and learn the theories .. that way u know what adjustments do what and when to make them...set goals on being smooth and doing laps.. smooth Is fast
Ok. Are you racing at competition rc?
Yep b back in may
Ok. Did you get that pm from me?
Didn't get anything
Didn't get anything
Where can i get the xxx main setup guide?
James can order it for u
