HPI Baja 5B pinion bolt.
Old 08-15-2012, 11:11 AM
Trader Rating: 9 (91%+)
Default HPI Baja 5B pinion bolt.
I was driving my 5B and the tires stopped turning. I took apart the gears, and saw that the pinion bolt was split in half! I ordered the parts, but has anyone else had this problem, or know how to prevent it?
TMistak is offline
Old 08-15-2012, 04:10 PM
aaron2u's Avatar
Trader Rating: 47 (100%+)
Yep! common issue with the baja line. Drill and tap out your clutchbell to the next larger bolt size. Or, upgrade to a turtle hd clutch and be done with it. there have been used setups around for $80-$90 in near new condition.
aaron2u is offline
Old 08-15-2012, 08:39 PM
Dan
Dan's Avatar
Trader Rating: 54 (100%+)
You can buy a 12.9 rated bolt that is available at DDM. It can still bust but not as easily as the stock bolt. The pinion bolt issue is definitely a known issue with the Baja.
I have the Turtle HD clutch on my Baja and I haven't ran into any problems since. Its pricey though.
Dan is offline
Old 08-16-2012, 12:47 PM
Venom1836's Avatar
Same thing happened with me, I just bought the replacement part and I havent ran into the problem again.
Hope fully I wont need to upgrade, 80-90$ is alot for a pinion.
Venom1836 is offline
Old 08-17-2012, 11:52 AM
dracy69's Avatar
if you use a tiny drill bit try drilling into the screw as dead center as possible and threading out the broken screw. That's how I got mine out.
I have had it happen once in 3 years so I guess I am doing well (knock on wood).
dracy69 is offline
Old 08-17-2012, 11:58 AM
TMowery's Avatar
A much easier way is too reverse the bolt and run it through the back of the clutchbell with loctite on it and the put you pinion on and double nut it and it wont snap of or anything.
TMowery is offline
