RC10L
Old 02-21-2012, 06:50 PM
Default RC10L
I have a Associated RC10L pan car and was wondering if the rear bulkeads from the RC10R5 will fit it. Thanks in advance
Tyler64 is offline
Old 02-21-2012, 07:02 PM
SWTour's Avatar
No,
The 10r5 is the 3rd generation rear pod plates and are metric.
Would be nice if someone would make an upper and lower for a wide 10L that would take more modern Pod plates though...
SWTour is offline
Old 02-21-2012, 07:12 PM
I have a 10L or a 10L2 (don't know the difference)
Anyways, I need to replace the bottom plate as well as the left rear bulkhead. Ive found an origonal bulkhead in plastic but would like to get the aluminum one if available.
Tyler64 is offline
Old 02-21-2012, 08:24 PM
SWTour's Avatar
I had some Magnesium bulkheads for the 10L back in the 90's, but they were aftermarket. I believe Associated only made the plastic ones for the L and L2. (The L2 I believe were the 200 mm instead of 235 mm cars with a semiteric t-plate instead of the offset....but don't hold me to that, I'm not sure)
SWTour is offline
Old 02-21-2012, 08:46 PM
Id be open to changing the whole thing from the t-bar back. I don't race it, just mess around with my brother in the basement and in parking lots and all. Just need to get it fixed....
Tyler64 is offline
Old 02-21-2012, 09:38 PM
SWTour's Avatar
The L3/L4 Tplate and rear pod can probably be adapted to work...but those are Triple Shock cars and don't have the spot in the upper plate for the original Damper discs. There was a L3 "Touring" car that used those, but the upper plate is hard to find.
Check Ebay for the Bulkhead pieces you need too, I am always searching for ASSOCIATED 10L stuff
SWTour is offline
Old 02-24-2012, 11:02 PM
oreo's Avatar
Default Alu. 10L bulkhead
Greetings. Hey Tyler, try contacting Niftech(Ohio)-They may still have the Bulkhead in stock.Good luck.
oreo is offline
