1/10th scale Dirt Oval tire question
I have a Losi XXXCR buggy converted to a DLM and was wondering would the Losi Slider tires/wheels work? Also are these the tires/wheels people are using on their Slash coversions? Thank you in advance for any advice!
yes, you can use the rim and tire on the buggy. the slider rims are a little narrower that a std truck rim, so they don't offset as wide. I have seen some use them on S/C, but they don't make fronts that wide that will hold bearings. RPM makes rims also that look good. you can also run foams from BSR and RC4Less
Thank you for the info!
