Ford escort MK II 1/5
Old 06-07-2012, 11:59 AM
  #31
spitfireV's Avatar
Jup,
yes the are original old FG tires , so i cut ith by myself.
The bumper are made from Pe (polyetheleen strips )
regards
spitfire
spitfireV is offline
Old 06-07-2012, 03:57 PM
  #32
Ok. Thanks for sharing!
Lars in Norway is offline
Old 06-08-2012, 09:52 AM
  #33
Default Escort
Hi Spitfire
The body looks is looking great . Well done!!
Umesh Gohil is offline
Old 06-08-2012, 12:09 PM
  #34
LSVTIEG's Avatar
Awesome work! The man definitely has skills. I wish I could find an eg6 body. what do you charge to a body?
LSVTIEG is offline
Old 06-09-2012, 12:24 PM
  #35
Are you using 2 mm lexan for these bodies?
Old 06-09-2012, 12:41 PM
  #36
spitfireV's Avatar
@ Lars in Norway
Hi, i make the body's off Vivak (Pet G) 1.5mm
for lexan is my haether not strong enough .
regards
spitfire
Old 06-09-2012, 05:08 PM
  #37
Ok, so how is this type of "plastic" compared to lexan/ploycarbonate then? Does it have the same strength?
Old 06-10-2012, 05:38 AM
  #38
spitfireV's Avatar
@lars in norway
jup,
lexan is stronger, but vivak (petG) is ok tho make the body's ith is a little bit softher as lexan.
regards
spitfire
Old 06-10-2012, 05:00 PM
  #39
Softer can be good as they maybe will flex more than lexan, making it more impact resistant.
Old 06-10-2012, 05:14 PM
  #40
Another question: does the Vivak comes with a protection film same as the lexan does? Then it is not necessary to cover the whole body before painting.
Old 06-11-2012, 12:59 PM
  #41
spitfireV's Avatar
@lars
Hm,Hm , i most move the protection film befor haeting .but tho place the film back iths don't go.
regards
spifire
Old 06-11-2012, 05:27 PM
  #42
Have you tried to vacuum form anything with the protection film on? Or is it impossible to get it off after heating and forming the Vivak sheet?
Old 06-12-2012, 01:47 PM
  #43
spitfireV's Avatar
@ lars,
yes i have tried but ith don't go , everything melts together.
But for painting , you don't need the film , you most painting
tho the inside .
regards
spitfire
Old 06-12-2012, 05:18 PM
  #44
Yes i know, i always paint on the inside, so just a little mask around the edges on the body will be enough, and a plastic bag or something to cover it all up
Old 07-01-2012, 08:54 AM
  #45
spitfireV's Avatar
Hi,
here wy are again.
I have som thime tho paint the MK II and make som update's , ligcht's and the
backspoiler.
hopfully you like it.
Now iths waiting about the files tho print the stickers.
Sombody make it for my.
regards
spitfire
