MCD Racing W5 Short Course Truck
Saw this up on largescalerc, looks pretty good.
http://mcdracing.com/cars/W5/01.jpg The Powerful Beauty MCD W5 continues to define the large scale off-road segments with it's cutting edge technology and build-quality. Technical superiority, unrivalled endurance, terrific 4WD handling and strong emotions are the qualities that have always set MCD apart in the world large scale RC scenario. The same values lie behind the W5, the latest model in the brand, embody the marriage of design and technology, set in the very DNA of any MCD. W5's bold, aggressive styling is conveyed by the superior MCD quality V4 chassis. Viewed in profile, the W5 states a sense of poise and strength, with a unique hood scoop and huge fender arches housing large 190mm Xross-Max Series Tyres and stylish 7-spoke wheels providing a powerful posture. The MCD W5, a powerful blend of strength, agility and beauty is the new Short Course truck for the most demanding active off-road enthusiasts. The W5 Features * Fourth generation chassis & suspension arms * Sophisticated 4WD Shaft Driven mechanics * Ultra strengtned chrome drive shaft and axle * Factory assembled chassis * Differential spiral bevel gears & diff house * Hard anodized alloy roll-cage * Coil-over hydraulic shocks & progressive springs * CNC machined T6 aircraft alloy chassis * 24 mm hexagonal rim-blocks * Strengthened lower&upper long wishbones * New 190mm Xross-max off-road tyres * New 7 spoke wheels * Solid and durable side guards * Water-resistant receiver and battery box * Clear body shell * Ultra durable, heavy duty central steel double disc brake rotors and bronze pads * New steel-reinforced extended front shock towers * New extended shock absorbers * Ultra hardened steel transmission gears * Fully adjustable sway bars * No-Stress-Effect polyamide front bumper with quintuple lamp pods * No-Stress-Effect polyamide rear bumper with mud protection * Pre-cut W5 Decal Set * Improved CVD Shafts * New front axle for CVD with slot * New diff output couplings * Improved brake linkage Technical Specifications Length : 895 mm Width : 495 mm Overall height : 320 mm Ground clearance : 30-90 mm Weight : 12.5 kg (Chassis-only weight:9.2 kg) Wheelbase : 532-540 mm Trackwidth : 402/402 mm Chassis material : T6 Alloy (4mm) Suspension : Non-parallel non-line independent Caster angle : 0-6 Adjustable Camber angle : Adjustable Toe angle : 0-3 Degrees Roll Center : 3 Position Adjustable Ackerman : 2 Position Adjustable Front Kick-up : 10 Degrees Rear Squat : 5 Degrees Shock absorber : Coilover Oilfilled Transmission : Full-Time 4WD Shaft driven Gear ratio : 4:3 to 12,3:1 (12 different GearBox ratios) Tyre size : 82 x 190 mm Engine type : Zenoah - CY 26cc, 27cc, 29cc * PO#: 009300V4 W5 Short Course Truck - w/o Engine http://mcdracing.com/cars/W5/04p13.jpg http://mcdracing.com/cars/W5/04p19.jpg http://mcdracing.com/cars/W5/04p27.jpg http://mcdracing.com/cars/W5/04p32.jpg |
a Conversion kit is on the way and for the buggy you will need to get the longer rear shocks for the front as well as the shock towers from what I can tell.
