whats your fastest 1/8 scale car or buggy?
heres mine ofna lx1e 51/26 gearing grp tires mamba monster 2inches off the ground got tri level nitro house wing stock had to much down force rear diff spooled gives you 5mph more on top side center spool also 6s 5000 nanotec 60c 8mm bullet connectors and external bec my personal best speed is 94 mph in 198ft might as well say 200ft motor timing normal or high timing for 300ft sprints
so no power junkies out there doing crazy speed mods feeeed meeeeee!!!!!
damn..mine was 87mph.
that's a 115mph set up you have to bring that 500 or 600ft booy you going in hundreds.i use turnigy also and the internal resistance is like having an elephant in a top fuel dragster also what motor?
I do not run electric. I know they are instant torque and power but they just do not have any soul. But each to there own. I only run large scale now. With electric large scale the run times are just way to short for me. I like being able to get 45 plus minutes of running before I have to top up and go again with my gasser. But that is just me.
mmm speedo 2650,zero timing 8mm bullet conn.ofna lx1e buggy on road conversion 1" off the ground 51/28 7s 60c nanotec 5000mah battery 200ft marked off. final speed for 200ft 106mph oh yeah added capacitors disabled mmm bec separate bec no breakes drag breaks set due to voltage ripple
