Go Back  R/C Tech Forums > General Forums > Oval, Larger Scales and More
LOSI 5IVE-T 4WD OFFROAD RACING TRUCK >
Like Tree18Likes
Old 05-17-2019, 09:32 AM
  #1486
FangsCPO's Avatar
The aluminum steering knuckles are stock and no I do not sue the aluminum dual servo mount. The plastic stock one works just great for me.
KR145 and gavsta72 like this.
FangsCPO is offline
Old 05-23-2019, 07:44 PM
  #1487
RDucky47's Avatar
I run a Bartolone piston port 32 in my buggy and it hauls. At the track Iíve been asked a few times what engine it is.
RDucky47 is offline
Old 05-24-2019, 11:19 AM
  #1488
KR145's Avatar
what clutch and gearing do you run ?
KR145 is offline
Old 06-10-2019, 11:32 PM
  #1489
RDucky47's Avatar
i run a MIP clutch and 18/58
KR145 likes this.
RDucky47 is offline
Old 06-11-2019, 11:13 AM
  #1490
KR145's Avatar
Bartolone Racing .32 Ported
gavsta72 likes this.
KR145 is offline
Old 06-24-2019, 09:16 AM
  #1491
MD
MD's Avatar
Trader Rating: 130 (100%+)
Has anyone had success in installing a roto start using and electric drill in a 5ive T? Thank you.
MD is offline
Old 06-24-2019, 09:20 AM
  #1492
Currently using the Troy Built one way start adapter and a threaded coupler with drill. So far, so good.
https://www.lowes.com/pd/genuine-parts-electric-start-drill-bit/1000860496?cm_mmc=shp-_-c-_-prd-_-sol-_-google-_-lia-_-154-_-trimmersedgersandaugers-_-1000860496-_-0&kpid&store_code=1524&k_clickID=go_1793151301_685 19298239_346820825233_aud-549623685082la-352051078504_c_9027276&gclid=Cj0KCQjw6cHoBRDdARIsA DiTTzZpmHaaxjRpxKAK0FyYilhHCwH3Bpe0uYjubBL9vB8UPfd g9KEfuBMaAoRIEALw_wcB
pfrank1 is offline
Old 06-24-2019, 02:34 PM
  #1493
MD
MD's Avatar
Is there room to get that into the rear of the motor? I would like to see a picture to it in use. Thanks for your response.
MD is offline
Old 09-12-2020, 06:30 PM
  #1494
FangsCPO's Avatar
The 2020 West Coast Nationals will be held at the Good Ol' Boyz RC Raceway in Bakersfield, California. Here are a few highlights from last year's racing action. You don't want to miss this race. It's going to be a awesome!
If you are interested in racing or learning more about the 2020 West Coast Nationals check out these FaceBook pages for more info: OBR Core Team News, Good Olí Boyz RC Club Raceway, Fear Farm 1/5 Scale RC Track Arizona and MOD
FangsCPO is offline
Old 10-11-2020, 07:23 PM
  #1495
hookedup's Avatar
Hey guys.. looking at a 5T roller V2.. can anyone tell me the difference between the 2.0 and the V2? Curious if parts are interchangeable between the two and or are still available..
thanks
hookedup is offline
Old 10-12-2020, 01:23 PM
  #1496
gavsta72's Avatar
thanks
2.0 is the v2 so no difference there
90% of the v1 and v2 parts are interchangeable, it's only the area around the centre driveline that has had major changes
To reduce the front driveshaft angle, the centre diff has been flipped around and moved about an inch back to the rear, and 1/2 an inch toward the centre line. This means the v1 centre driveshafts are a different length, and they are now also dogbones, as opposed to a dogbone on one end, and a coupler on the diff input end. The spur gear faces the front now. The engine mounting holes are also different as they're for the Zenoah engine, as opposed to the CY engine on the v1, so engine spacers are also different
hookedup likes this.
gavsta72 is offline
Old 10-16-2020, 09:29 PM
  #1497
hookedup's Avatar
[QUOTE=gavsta72;15701249]2.0 is the v2 so no difference there
To reduce the front driveshaft angle, the centre diff has been flipped around and moved about an inch back to the rear, and 1/2 an inch toward the centre line. This means the v1 centre driveshafts are a different length, and they are now also dogbones, as opposed to a dogbone on one end, and a coupler on the diff input end. The spur gear faces the front now. The engine mounting holes are also different as they're for the Zenoah engine, as opposed to the CY engine on the v1, so engine spacers are also different[/QUOTE
thanks!!
so the fastest way to tell would be to see if the front driveshafts has a dog bone 2.0 or a coupler 1.0
hookedup is offline
Old 10-24-2020, 05:26 PM
  #1498
gavsta72's Avatar
[QUOTE=hookedup;15703213]
thanks!!
That's one way I guess. Another way is to see if the spur gear is facing toward the front and not the rear.
The steering bellcrank is also different, plus the v2 has the TLR gold(ish) couloured shocks with bleeder caps
Are you looking for a used roller or something? if you have pics post them up. I always see people selling "Losi 5iveT" when in actual fact I can tell it's one of the clones. You need to know what to look for
gavsta72 is offline
Old 11-13-2020, 12:39 PM
  #1499
gavsta72's Avatar
Few pics here of new 5iveT 2.0 build. I'll take it out today and start breaking in the engine
- OBR 34 Signature Series with "Frosty" engine wrap
- Joker Designs "Game Over" body wrap on the 30n Big Fles body, AAA rear wing
- VRC big bore pipe
- Hilantronics 7000 70kg steering, stock Losi throttle/brake servo
- Modified RC centre diff
- MOD rear diff inserts
- MadMax giant grip tyres
gavsta72 is offline
Old 11-20-2020, 09:19 AM
  #1500
I see some amazing machines here. Can you help me understand the current status of 5th scale off-road racing in the US? I see all our Texas tracks have closed. Is there any racing in neighboring states, OK, LA, NM? Even if its a monthly race. I used to race HPI Baja and FGs back in the day and it was fun.
rcindia is offline
