Go Back  R/C Tech Forums > General Forums > Oval, Larger Scales and More
Rc8B to Latemodel conversion >
Old 08-16-2010, 03:20 PM
draggin87's Avatar
Trader Rating: 32 (100%+)
Default Rc8B to Latemodel conversion
What parts are need to convert rc8b to latemodel?
Part numbers and where to get them would help, thanks
draggin87 is offline
Old 08-16-2010, 04:27 PM
If you want or have to use a stock chassis plate:
www.dynotech-racing.com makes shock towers in two heights, one for touring car shocks and one for Revo length shocks. The Losi rear body mount fits these towers and the Losi front body mount is almost a direct fit on the stock RC8, you will need to thin down the area where it slides under the front diff.
If you are looking for an aftermarket offset chassis:
Look at the GFRP post for the "mistress" chassis in this forum. Everything from your stock car bolts to this chassis. Use the Dynotech shock towers, or I believe GFRP is working on their own design also. The Losi body mounts fit this chassis with no modifications.
With either chassis you can use the A and B plates from the front of the RC8B on the rear of the car in the C and D plate locations. This gives you more Dirt Oval friendly toe adjustments.
There are some other tricks with Losi one-way diffs and lockers that are pretty simple mods, but the aforementioned stuff will get you a very competitive car on any track.
Love mine!
Stetler17 is offline
Old 08-16-2010, 05:01 PM
I'm not seeing any rc8 towers on the dynotech site. May require a phone call?
x8racing is offline
Old 08-16-2010, 05:21 PM
draggin87's Avatar
yea i didnt see them either.........
Old 08-16-2010, 05:37 PM
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Shock Towers
Dustin from GFRP is finishing cutting tower tonight, they should be available in about 48 hours...
JFuel11 is offline
Old 08-16-2010, 05:50 PM
draggin87's Avatar
WOW.......really on the cutting edge here..........wheres crazyfrog? He needs to keep up on this thread
Old 08-16-2010, 05:57 PM
Is a converted buggy a better option over a purpose built dirt oval car? This could get expensive!!!!
catchinup is offline
Old 08-16-2010, 06:28 PM
draggin87's Avatar
well i think most major brands are converted buggys. Ofna is based of the old mbx platforn, same with the dm1. Losi based off the 1.0.
The only purpose built LM cars are expensive and might be hard to find parts for
Old 08-16-2010, 06:32 PM
I think I might build a AE
x8racing is offline
Old 08-16-2010, 06:36 PM
Ya you are correct, they all are from a buggy.....Man what to do
Old 08-16-2010, 06:46 PM
Alright, I am getting tempted. Would be great to get into oval with a AE! Got some questions for ya. These shock towers aluminum? What kind of shocks are needed for the conversion? And this is the big one....what do you do for a setup I like to think I know a bit about off road but oval is a whole new ball game. But damn does it look fun
Old 08-16-2010, 06:53 PM
Ya me too, but will have to go the whole 9 yards....chassis and towers, gotta go big with this one!!!
Old 08-16-2010, 07:04 PM
http://www.rctech.net/forum/oval-lar...-mistress.html
This will give you more links as well as pictures. I got the shock towers cut tonight. They are made from aluminum to try to keep some of the cost down. They will work with the Revo's and the Losi shocks. They may work with others but I'm not 100% sure. As for setups and other questions you are best off to ask Stetler17 on here. He is one of the main guys in developing this car.
racer57 is offline
Old 08-16-2010, 07:13 PM
Great! Thanks for all the info!
