GT8 Class--buggy-based on road electric!
#812
Practice
Charlie:
Are you open for practice tomorrow. Just finished the conversion of the Kyosho ST-RR Truggy to GT and chased the kids on the street all day yesterday. Dying to check it out on the track. I need to get some of those PMTs as I am running the $9 Kyosho GT tires right now.
#813
The car definitely works, however, I think the biggest improvement is the center diff.
For those that are still running the spool in their GTP2E, get the center diff for it. It is 100X easier to drive. You'll be glad you did.
#814
Super Moderator
Charlie:
Yep CAL Raceway will be open from 4-10pm. I need to get my Body back from Associated...they are working on their own GT8 car as we speak! Glad ur back from ur work stuff, we been getting a pretty good turnout on Saturdays!
#815
Great see you guys tomorrow.
#816
More specifically, the shock bodies and shafts of the front shocks. So front shocks X 4.
#817
Should have my DM-1 Spec from UPS today!! YIPPEE!!
#818
I've just got some wiring to do and I should be ready to go.
#824
Well I got my DM-1 S in finally (man I love the smell of new RC) I am getting the Tekno conversion for it and have a couple of questions if you guys don't mind.
1 - I thought I read where the Tekno conversion chassis is shorter than the stock one. Is this true? And if so will the lid that came with it fit, or will I need to get another one?
2 - Do you guys keep the 2 speed or ditch it for a 1 speed. Can you lock it so reverse is possible?
3 - I would be interested in the speed and torque you guys are using for servos.
4 - And are the mechanical brakes preferred on these?
I appreciate any help you guys might have as I am new to the pavement.
Thanks in advance
Thanks in advance
#825
Tekno conversion chassis is identical to stock.
Tekno conversion allows you to use 2 speed if you wish but will require brake servo.
I never use anything less than metal gear, 200 inch oz servos on steering or throttle.
Tekno makes a trick clutch setup that allows you to run a brake servo if you wish. I do not use a brake servo on my electric car, but I'm not racing.
Hopes this helps.
Hopes this helps.
