Go Back  R/C Tech Forums > General Forums > Oval, Larger Scales and More
GT8 Class--buggy-based on road electric! >
Like Tree12Likes
Old 06-28-2010, 04:25 PM
  #31
Cool
Originally Posted by Foxxrocket View Post
Hey will, What battery are you using?
Hobby King Turnigy 4500 mah, 4S, 30-40c. They were dirt cheap! I believe I paid $39.00 each for the 2 I have. It cost about $30.00 to get them here from Japan. So figure about $55.00 per pack. Still $100.00 or more less per pack than buying with a name brand in the US.
When I recived them I checked the balance, 1 pack perfect, the other had a low cell that required me to single cell charge through the balance tap (it was a pain in the arse to make up an adapter to charge 1 cell through the balance lead, I had to figure out what cell it was, then determine which positive and negative lead to use for that cell, and if you have to ask, I will not tell how I did it, these batteries are dangerous if you are not really, really carefull!)
My balancer running in series with the charger will only discharge the high cells. I needed to bring up the low cell first. After doing this several times the cells appear to be very close without the low one anymore.
I balance after I run the pack down, then charge, then balance again before I use the pack (once they are close, only takes a few seconds on the balancer). I think this is the best way to keep them in top shape.
My charger is only a 50 watt charger, so I plan on investing in a Hyperion 100 + watt charger (I want to charge at 2C - 3C). Plus the Hyperion chargers balance while charging (balancing is done in parallel while charging, not in series), much better way to charge.
I have never owned a $200.00 battery, but if these last and continue to perform I never will!
williamw is offline
Old 06-28-2010, 04:35 PM
  #32
teknorc's Avatar
Originally Posted by Raman View Post
Why not just do away with the clutch and use the sensors.. No need for the additional hardware eg, clutch, brakes, servos etc.
You can run it (Tekno/DM-1) either way, with or without the clutch. You can run it with or without the 2-speed, depending on the size of the track. You can use our new Traktion Drive too (with or without mech brakes). However, we prefer the mechanical brakes in this application because it allows the motor and ESC to run MUCH cooler.
I borrowed some 1/8th offroad buggy tech for my current setup. I'm running a center diff with 500K fluid. It allows for a little better traction and it doesn't 'hop' under acceleration. It also helps with braking as I can use a little more rear bias to avoid pushing into corners under braking, so the car is rotating better in and out of the turn. For smaller parking lot tracks, the single speed is plenty fast. If I was at a bigger track, I'd drop the 2-speed back in without the CD and bias.
I originally had my car setup with direct drive + mech brakes, then switched to Traktion Drive + mech brakes. I have settled on the Elektri-Clutch at this time. It is by far the smoothest option we've run as it eases in and out, on and off power. It eliminates cogging and allows everything to run cool as mentioned before.
The brakes and clutch were a hot topic in the 1/8th electric buggy discussion a couple years ago when we first introduced it. Our kits now offer a power delivery option for everyone's taste. Direct drive + motor brakes, DD + mechanical brakes, Elektri-Clutch + mech brakes, or Traktion Drive w/ motor or mech brakes.
At this time, I like the DM-1 chassis because it is more purpose built for the application (different arms and hubs to lower the chassis). We also like it because there is a purpose built kit for it . The Losi L8 makes for a pretty neat conversion as well.
Either way you go, you can't really go wrong with this class. We had such a blast running an actual race with 6 of these beasts screaming down the straight. We can't wait to do it again!
teknorc is offline
Old 06-28-2010, 04:37 PM
  #33
teknorc's Avatar
We're thinking about heading over to WCRC tomorrow (June 29th) to run our eGT's. We don't have enough for a class, but if there are some of you in the area that can make it, let us know and we can get some racing going on.
WCRC, Tuesday June 29th. Can anyone make it?
teknorc is offline
Old 06-28-2010, 04:42 PM
  #34
Raman's Avatar
Trader Rating: 59 (100%+)
William,
I just ordered the turnigy 4500 LiFe 3s packs. I already own a pair of the 2S 4500 LiFe, plan on running 5S with them.
Overall I'm happy with the turnigy packs. For the price you can't beat them. I also run them in my planes as well.
Raman is offline
Old 06-28-2010, 04:45 PM
  #35
Raman's Avatar
TeknoRC,
Thanks for the informative post. What is the traction drive?
Raman is offline
Old 06-28-2010, 04:47 PM
  #36
Cool Very Cool!
I had never seen or heard of your Traktion drive system. Wow. I will have to try one of those. Can you tell me how much length needed on the motor out put shaft? The Kyosho mount almost requires the newer Novak short pinions.
williamw is offline
Old 06-28-2010, 04:48 PM
  #37
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
Rice Man let me know when the next time you guys run I will make the trip down their.
Originally Posted by rice_man View Post
Nice to see this thread open up here. We are trying to get this class going down here in San Diego. We had our first club race a couple weeks ago. Here are few pics. There are 3 DM-1 Tekno Conversions (Impakt, Red Bull and Lightning Mcqueen), 1 DM-1 RC Monster conversion (Rising Sun), 1 Losi conversion (Tekno paint) and 1 Kysosho GT-2 home brew conversion (Corvette)
By the way I painted all but the Corvette and Rising Sun bodies. Enjoy the pics.
snrscion is offline
Old 06-28-2010, 04:49 PM
  #38
William,
I wanted to stick with a hard case lipo until I am really comfortable handling them, but 5S with the much safer LiFe cell should be equal to a 4S lipo.
williamw is offline
Old 06-28-2010, 04:52 PM
  #39
teknorc's Avatar
TeknoRC,
http://www.teknorc.com/product_info....oducts_id=1079
There is some discussion about it in the Tekno conversion thread (in electric off-road).
It's basically a slipper pinion.
You do need to space the motor back a little bit to accommodate the clutch bell assembly.
Some of the longer motor shafts may have to be cut down depending on the chassis/mount you use. I think 17-19mm works.
It doesn't work on direct to diff type mounts, it requires a Tekno type motor mount setup or some other way to space it back a little bit.
teknorc is offline
Old 06-28-2010, 04:55 PM
  #40
teknorc's Avatar
Originally Posted by js058515 View Post
Raman, I am willing to head down to San Diego to drive with other GT's. I am sure we could learn a lot from the Tekno guys regardless if we use their stuff or not.
js,
Let's do WCRC tomorrow night. Come on!
teknorc is offline
Old 06-28-2010, 05:01 PM
  #41
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
You should head over to WCRC tomorrow and race with Danny and me. Close for you and their track is great.
Matthew_Armeni is offline
Old 06-28-2010, 05:04 PM
  #42
We're running tomorrow at WCRC, closer for you then that parking lot race in the photos.
Old 06-28-2010, 05:08 PM
  #43
Raman's Avatar
Originally Posted by williamw
Quote: Originally Posted by Raman William, I just ordered the turnigy 4500 LiFe 3s packs. I already own a pair of the 2S 4500 LiFe, plan on running 5S with them. Overall I'm happy with the turnigy packs. For the price you can't beat them. I also run them in my planes as well. I wanted to stick with a hard case lipo until I am really comfortable handling them, but 5S with the much safer LiFe cell should be equal to a 4S lipo.
That's why I went with the LiFe, no worries about damage. They're also more forgiving when it comes to balancing and charging. My esc does not have a low voltage cut off for LiFe, so I turned it off.. When my car came to a crawl the minimum voltage was way above the 2.0 per cell.
You can compensate for the lower nominal voltage by gearing up. For example, on my 1/10 scale onroad, with a 3.5 system, I was running an fdr of 10.5 with 2S lipo. With the LiFe, I'm down to 8.5 with no heat issues on motor, esc no battery.
Raman is offline
Old 06-28-2010, 05:10 PM
  #44
Raman's Avatar
Originally Posted by teknorc
Quote: Originally Posted by js058515 Raman, I am willing to head down to San Diego to drive with other GT's. I am sure we could learn a lot from the Tekno guys regardless if we use their stuff or not. js, Let's do WCRC tomorrow night. Come on! __________________ Tekno RC / Impakt RC www.teknorc.com / www.impaktrc.com
Lol... Theres one problem with that bro.. My car doesn't have a centre drive gear, pinion or batteries. So you would have to toe me around the track rofl.. It's not done yet!
Raman is offline
Old 06-28-2010, 05:41 PM
  #45
fast pauly's Avatar
the CARS gt and rising sun gt shells are sick nice work
fast pauly is offline
